Go to Post there is no such thing as too many parts or useless parts, only parts you dont need yet. - Cuog [more]
Unread 04-01-2015, 17:35
Bluejackets's Avatar
Bluejackets Bluejackets is offline
Bluejacket Robotics
FRC #5464 (Bluejacket Robotics)
Rookie Year: 2015
Bluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to behold
Tank treads
we need to find out how to design and build a tank tread for our robot please help
Thanks
Unread 04-01-2015, 17:45
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Tank treads
Thanks
I would advise against tank treads. Is there any reason you want treads and not 6/8 wheel tank drive?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 04-01-2015, 17:47
Re: Tank treads
I think he's trying to get help for their offseason robot.
Unread 04-01-2015, 17:53
Bluejacket Robotics
Rookie Year: 2015
Re: Tank treads
treads are better with inclines and tend to stay level better on an incline such as the one in this years game
Unread 04-01-2015, 17:58
Re: Tank treads
I really hate to do this to you...
PROVE IT. Prove your last statement.
I need an awful lot of evidence, after seeing 8WD, 6WD, 4WD, sometimes a 2WD, Mecanum, swerve, octocanum, Nonadrive, AND H-drives all handle ramps that are far steeper and higher than this year's 2" high, 16-degree ones. With ease. Without tipping over.
Unread 04-01-2015, 18:04
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Tank treads
I would agree that it might be easier to use tank treads for the humo, but wheels will work fine too.
Unread 04-01-2015, 18:07
Bluejacket Robotics
Rookie Year: 2015
Re: Tank treads
well considering if we do a 4 tread tank drive and the front treads will go up the slope before the body of the robot will and the body of the robot will stay level with the ground with the support of the back treads we can stack a tower of totes on our robot and not worry about the incline and have a device to push the tower of toes onto the scoring platform with ease
Unread 04-01-2015, 18:34
Re: Tank treads
Wait, what? Stop, think, RETHINK.
First, you're only dealing with a 2" platform. That's nothing. I've seen robots go up far steeper, far taller platforms. And if you're targeting the STEP, then you shouldn't be going on there at all. (And I'd still point out that I've seen robots climb that much of a step before.)
Second, the only thing worse than tank treads is >2 tank treads. Tank treads are notorious for breaking or for coming off at the least opportune time. Multiply by 2, and watch your problems multiply by at least 2.
Third, if your front treads go up the slope and the robot is still level, that means you've installed a suspension to KEEP it level. So you've got suspension problems on top of the tread problems (potentially).
Fourth, it's entirely possible to maintain control of a stack of bins without requiring the drivetrain to be level. For example, by building a cage around it.
My advice is simple: Start by building the KOP drivetrain. If you haven't done that yet, do it now. You'll be surprised just how easy it is to work with for building that perfect manipulator.
Unread 04-01-2015, 18:53
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
Re: Tank treads
Tank treads will not fix this "problem". The instant tread pod (whatever you want to call it) begins ascent of the ramp, the pitch of the frame will change, unless you create a controlled suspension system to level the frame.
Take it from a team that mastered tank treads and still hasn't built them in over a decade - it's not worth it.
Team 501 Academic Advisor, Systems Build Mentor
Unread 04-01-2015, 19:03
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Re: Tank treads
Tank treads are expensive, add an unnecessary level of complications, could cause you to blow your main breaker, and turns are very taxing on the system and require a lot more of your battery. If you want to keep the robot level and stack the totes, just make your mechanism hold the stacks 3" from the first wheels of the robot, that simple. It's not bad to explore your options, but in this game, a simple kitbot will work much better than it would've last year. Last year custom drivetrains were really useful to withstand the beatings, avoid defense, and traverse the field quickly. This year however, you shouldn't need to build such a robust, and fast drivetrain. The kitbots offer good methods of attaching superstructures, and are a generally good option. If you want speed, you can use two CIMS with the gearboxes in the kit already, if you want control you can write code that gives you a fast and slow option. Team 1114 has a really useful and informative document about this, Here I'd suggest reading it and seriously consider not doing tank treads.
Unread 04-01-2015, 19:07
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Re: Tank treads
I have to agree with EricH, don't go there. ESPECIALLY if you haven't played around with them in the off season. Having successfully used them twice in the last 17 years we would NEVER consider them for this year's challenge. In fact, they were the last option even considered.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 04-01-2015, 19:10
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Re: Tank treads
As another team that loves tank drive and has mastered the power of tank drive this is not the game for them. With all the other wheel configuration out there go with something easier and more moveable. If you really want to run with tank drive do a search on this web site you will see them all.
Building FIRST robots since 1995
BVT Robotics
