Go to Post ..."A bad day at college is always better then a good day at work" - KyleGilbert45 [more]
Unread 06-01-2002, 12:02
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
Additional Joysticks/Modification
Ok, they said in the rules we cant modify certain things (and specifically said joystick)
Does this mean we cant use a different joystick of our own?
Also, we were looking at rotating the handle 45 degree's and rewiring the buttons, the joystick electrically wouldnt function any different. Is this still iligal?
Unread 06-01-2002, 13:09
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
Jordan, calm yourself.
You cannot alter the joysticks included in the kit, nor can you use other commercially available sticks, but you CAN build your own. Just remember to reprogram to make your custom stick work. Best of luck.
Unread 06-01-2002, 13:48
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Jordan, calm yourself.
I thought we can use commercially available joysticks, as per the additional hardware list?
Joystick, Steering Wheel, or Pedals - 15 Pin (Not USB) PC Interface, up to 6
--Madison--
...down at the Ozdust!
Unread 06-01-2002, 14:03
Jordan A.'s Avatar
Micheal, just saw that on the additional parts list, so we can use another joystick, can we modify it? or do the rules apply to all joystics used in the control system?
I am calm Dan, as a cucumber
Unread 06-01-2002, 16:51
Jon Abad's Avatar
Jon Abad Jon Abad is offline
Boston Regional Planning Committee
Team Role: Communications
Jon Abad will become famous soon enoughJon Abad will become famous soon enough
Send a message via AIM to Jon Abad
It is my understanding that the rule is that you may use any joysticks or game controller that you like as long as they have a 15 pin connector.
I am unclear on the extent of allowed modifications but how are custom control interfaces created then?
Jon Abad
-Boston Regional Planning Committee
Unread 06-01-2002, 18:20
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
USB.....
I would kinda like to see them (FIRST) come up with a way that we could use USB ports (if thats even possible) cuz there are some pretty sweet joysticks out there....but they use USB connections...
Purdue Alumni
Cummins, Inc.
Unread 06-01-2002, 19:01
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Re: USB.....
Don't hold your breathe. USB is a much more complicated intereface than a joystick port is. It also uses serial data transfers as opposed to parallel which require encoding and decoding hardware on either end (in the joystick and in the interface).
Matt
Unread 06-01-2002, 19:16
mnkysp6353's Avatar
mnkysp6353 mnkysp6353 is offline
no team (Bagel Bytes)
mnkysp6353 is an unknown quantity at this point
Send a message via AIM to mnkysp6353
you can modify your joysticks in any way you want. Look at cyber blue last year with there funky joystick arm thing.
Unread 06-01-2002, 19:58
FRC Key Volunteer Trainer
AKA: CrazyNate
That, if I remember correctly, was something they custom made with potentiometers, rather than hacking apart a joystick. With the specifications of the input ports on the OI readily available, this is a possibility, most likely easier than taking apart a joystick and then trying to use the parts...and also, remember, as you point out, that they did that LAST year...just because something was allowed last year, doesn't mean it will be this year.
Nate Smith
nsmith@smythsoft.com
Unread 06-01-2002, 20:07
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
actually, we did a little of both. we pretty much just took off the actual stick and just use the inside wires and buttons. then that was all hooked up to the pots and so on. that wasn't my area of the robot. but i sure hope that we can do that again. using that arm thing is one of the reasons that we had such good control of our robot.
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 06-01-2002, 21:47
Question
Do u guys know if there is an adapter to go from a USB connection to a standard 15 pin gameport connection???
Just wondering because i know u can go the other way...(gameport to USB)
Just wondering....
Purdue Alumni
Cummins, Inc.
Unread 07-01-2002, 11:42
Yes there are adaptors availible: http://www.pccables.com/cgi-bin/orde...les.com&rcode=
I'm just curious why you need an adapter since USB joysticks aren't allowed.
Unread 07-01-2002, 18:50
Ok.....
Cool....didnt even know they made those....we are in the very very very earlier time of deciding on what "control device" we want to use.....and we never really looked at that rule.....
Purdue Alumni
Cummins, Inc.
Unread 02-03-2003, 19:16
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
I was dismayed to read that FIRST has banned all joystick modifications (mechanical or electrical), including modifications to joysticks that you bought. You have to dig through the jive forum to see this. I was surprised that no one blasted this out on CD since it is such a drastic change from previous years and the rationale is not very strong. I suppose it's a good thing they let us keep the OI.
Unread 02-03-2003, 20:16
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
Quick question: Can you make a connector to the OI so you can plug the joystick in and use the leds at the same port?
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Additional hardware list archiver 2000 5 23-06-2002 22:54
Is Air on the additional parts list??? Elgin Clock General Forum 12 06-02-2002 21:27
additional materials: mylar? Frank Toussaint Off-Season Events 3 02-11-2001 16:06
additional materials Penn Robotics Off-Season Events 1 01-11-2001 23:25
Are additional pulleys "cable fasteners"? kmcclary Off-Season Events 6 26-10-2001 01:56
