Go to Post I always wondered what would happen if two robots mated. - Greg Needel [more]
Unread 03-01-2015, 20:29
nick818 nick818 is offline
AKA: Nicholas Currault
FRC #2840 (Blue Tide)
nick818 is an unknown quantity at this point
Having trouble getting started with Eclipse
I've been following this guide to get started with the new C++ programming environment: Eclipse.
I got as far as "Creating your Benchtop Test Program", but then the SAMPLE PROGRAM ("Getting Started") wouldn't compile.
I was presented with several errors, but then I followed the instructions to right-click the project name, Index > Rebuild. After this, only two errors remained. One was on line 7, where the Joystick was declared; the error:
Multiple markers at this line
	- The type 'Joystick' must implement the inherited pure virtual method
	 'GenericHID::GetRawAxis'
	 'GenericHID::GetRawButton'
	 'GenericHID::GetPOV'
Another occurred on line 59 (the use of START_ROBOT_CLASS):
	- Symbol 'endl' could not be resolved
	- Invalid arguments ' Candidates are: ? HALReport(?, ?, ?, const
	 char *) '
	- Symbol 'cerr' could not be resolved
None of these errors make sense to me. Any help is appreciated.
Unread 03-01-2015, 20:42
dougwilliams's Avatar
dougwilliams dougwilliams is offline
Engineer - Controls, Electronics
FRC #2053 (TigerTronics)
dougwilliams is on a distinguished road
Re: Having trouble getting started with Eclipse
This just solved our problem - same problem, different thread. Thanks to RufflesRidge!!!
Originally Posted by RufflesRidge View Post
What happens if you re-build the project index as shown in the Rebuilding the Index step here: http://wpilib.screenstepslive.com/s/...p-test-program
Unread 03-01-2015, 20:51
This person mentioned they tried that. I would try it one more time, but if it doesn't work I would try building the project anyway, the build console may give a different error with more clues.
Unread 04-01-2015, 15:15
I tried building again, and the build console gave this error:
arm-frc-linux-gnueabi-g++ -std=c++1y "-IC:\\Users\\Driver Station/wpilib/cpp/current/include" "-IC:\\Users\\Driver Station\\workspace\\uralzzrdhary\\src" -O0 -g3 -Wall -c -fmessage-length=0 -o "src\\Robot.o" "..\\src\\Robot.cpp"
Cannot run program "arm-frc-linux-gnueabi-g++": Launching failed
Error: Program "arm-frc-linux-gnueabi-g++" not found in PATH
No binary file was produced.
Unread 04-01-2015, 15:20
Did you install the FRC toolchains from the installing Eclipse document? If so, try uninstalling them, rebooting, make sure the installer is copied somewhere on your main hard drive, then run the installer again. Open Eclipse and try building and see if the error still appears.
Unread 04-01-2015, 20:01
Thanks, that worked!
I can now successfully build and deploy to the roboRIO, but the errors still appear next to the line numbers and next to the scroll bar in Eclipse (but not in the build console). Is there any way to fix this?
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
I had a similar problem within Ecliplse. I even went to the trouble to find where the frc arm toolchain was (c:\frc\bin, in my case), and adding that to the system path. No joy.
Unread 04-01-2015, 20:51
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Eclipse's C++ indexer is really buggy. Just add #include <cstdint> right before you include WPILib.h.
Unread 08-01-2015, 11:20
dsgrieve dsgrieve is offline
FRC #1307
dsgrieve is an unknown quantity at this point
From Eclipse, Window > Preferences > C/C++ > Build > Environment
Ensure "Append variables to native environment" is selected.
Click "Add..."
In the Name: field, enter PATH
In the Value: field, enter C:\frc\bin
Click "OK"
Click "Apply"
Click "OK" to exit the Preferences dialog.
Unread 13-01-2015, 18:21
mr_abomination mr_abomination is offline
FRC #4733
mr_abomination is an unknown quantity at this point
Click "Add..."
Click "OK"
Click "Apply"
Now we're getting the following errors:
Program "g++" not found in PATH
Program "gcc" not found in PATH
Unread 18-01-2015, 09:11
I'm not sure if the current documentation says it or not, but in Beta we were told you can safely ignore those.
