Go to Post A thread already exists (and boy, does it exist!) on the topic: - Billfred [more]
Unread 04-01-2015, 20:52
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
pic: double tote auto?
Unread 04-01-2015, 20:57
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: double tote auto?
Might not be the worst way to get a tote set in autonomous.
Unread 04-01-2015, 21:18
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Yes, assuming you don't over shoot and leave the auto zone.
Unread 04-01-2015, 21:22
Amy33Amy33's Avatar
Amy33Amy33 Amy33Amy33 is offline
Alumni
FRC #2846 (FireBears)
Amy33Amy33 is an unknown quantity at this point
Isn't there a rule against throwing game pieces?
Unread 04-01-2015, 21:24
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Or worse, shoot it over the STEP.
Unread 04-01-2015, 21:25
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
No, you can throw game pieces, but just not over the step, with the exception of human players throwing litter on the other side. As long as the game piece doesn't break, throwing is fine.
Unread 04-01-2015, 21:32
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Can you cite that rule?
The rules that I've read say you can't throw game pieces over the Step. I haven't seen anything about throwing other than that.
Relevant rules I've seen:
G23: ROBOTS may not cause TOTES, RECYCLING CONTAINERS, and/or LITTER to completely leave the FIELD.
VIOLATION: FOUL for each item. If egregious, offending ROBOT will be DISABLED.
G24: ROBOTS may not cause TOTES, RECYCLING CONTAINERS, and/or LITTER to completely transfer from their side of the FIELD,
or from the STEP, onto the opposite side of the FIELD.
VIOLATION: FOUL. If egregious or strategic, RED CARD and offending ROBOT will be DISABLED.
And the most relevant part:
The following actions are prohibited with regards to interaction with FIELD elements (items A-D exclude TOTES, RECYCLING
CONTAINERS, and LITTER):
A. grabbing
B. grasping
C. grappling
D. attaching to
E. becoming entangled
F. hanging
G. damaging (exception: unintentional damage to LITTER)
H. tying
VIOLATION: FOUL. If the Head REFEREE determines that further damage is likely to occur, offending ROBOT will be DISABLED.
Corrective action (such as eliminating sharp edges, removing the damaging MECHANISM, and/or re-Inspection) may be
required before the ROBOT will be allowed to compete in subsequent MATCHES
Note that only E,F,G,H apply to the TOTES.
So there isn't a rule that explicitly PROHIBITS throwing around totes, UNLESS that will cause damage to it, which it might.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 05-01-2015, 19:12
NH Swag's Avatar
NH Swag NH Swag is offline
Representin' the Shire
AKA: Timothy Rice
FRC #1831 (Gilford Screaming Eagles)
NH Swag is an unknown quantity at this point
Does this risk breaking the totes? #swag
Unread 07-01-2015, 07:16
kbrowncny's Avatar
kbrowncny kbrowncny is offline
Mechanical Engineering Mentor
AKA: Kevin Brown
FRC #2168 (Aluminium Falcons)
kbrowncny is an unknown quantity at this point
Does "hanging" refer to using a hook to a lift from the edge of the tote?
Unread 07-01-2015, 07:25
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
That section refers to robot interactions with field elements, and A-D excludes totes...I would conclude that using a hook to lift the tote from the edge would be considered either "grappling" or "attaching to" - thus permitted.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
