Go to Post I lose track of what day it is during build season. - Gary Dillard [more]
Unread 04-01-2015, 23:23
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
pic: Year of Depth Cameras?
Unread 04-01-2015, 23:24
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: pic: Year of Depth Cameras?
How far away was the tote (in something like feet)?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 05-01-2015, 13:57
faust1706's Avatar
Derp. I didn't adjust the algorithm to call for the distance at the center of the contour from the depth map.
Here is the image with it outputting real distance in inches: https://www.dropbox.com/s/bsc1crj6gy...tance.jpg?dl=0
tl;dr: It's 171.14 inches
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 05-01-2015, 16:22
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
The Kinect does some unexpected depth processing that you may want to be aware of (or at least, it did in the past, and I don't think it's changed recently).
When you ask for the depth value of a specific pixel (and this is hard for me to put into words) it:
returns the distance to the closest point of the plane that:
-intersects the object in that pixel
AND
-is normal to the viewing angle of the Kinect.
This is easily observed by putting an object directly ahead of the Kinect, say, at 6 feet. Then, slide the object left and right. The Kinect will report that the object is still 6 feet away, even though as you slide the object to the left or the right, the absolute distance to the object increases!
This is very helpful for games, by the way - since the Kinect was originally intended to watch the human body, they wanted to report constant distance values for the depth of the player body even if the player body is not directly in front of the sensor.
However, if you're trying to find objects and navigate to them, you should be aware of this particular quirk. This means as you rotate the sensor, the reported distance of objects will change, even though their real-world distance has remained constant.
Unread 05-01-2015, 20:41
faust1706's Avatar
huh. I didn't know that. That's rather interesting. I don't see it being a problem because most routines would turn to line up, then drive to pick it up. Who knows though.
Unread 05-01-2015, 23:49
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Have you gotten a chance to use the Kinect v2 (assuming you're not using one in your example)? I've read that it uses time of flight to find distances instead of IR pattern recognition the old one uses. It has a greater field of view, higher resolution and frame rate, independent color channels, and longer range. Is it something you're thinking about developing with?
Unread 06-01-2015, 09:08
faust1706's Avatar
I would love to develop with it, but I don't have access to one.
Unread 16-01-2015, 00:59
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Note that Kinect v2 would require USB3 and lots of computation power, so integration of it on the robot would require a pretty powerful coprocessor or laptop.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 16-01-2015, 01:38
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Seems perfect for those Nvidia Jetson TK1 boards on FIRST Choice.
