Go to Post For fun, someone ought to spread out a bunch of petri dishes or something all over a regional and see what you bring home with you. Or not. - KathieK [more]
Unread 04-01-2015, 16:32
ThrowinRoses87's Avatar
ThrowinRoses87 ThrowinRoses87 is offline
AKA: Jeffrey Dennis
FRC #3534 (House of Cards)
ThrowinRoses87 is an unknown quantity at this point
2015 Scouting
I think this year is the easiest year for scouting because the ranking system will put the teams in order of OPR rather than win-loss which you can get lucky, i think that it is not perfect but i do think it is easier than previous years.
Unread 04-01-2015, 16:38
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
Re: 2015 Scouting
I'd be careful there. OPR is the offensive power ranking, which isn't particularly consistent with the average score. It will still be able to point out teams who had an better-than-average alliance partners, allowing them to seed higher than they should.
You should also consider that, like last year, the best alliances will not be made up of twins and triplets. Each robot will fit into roles the others cannot in order for success.
Field reset: Kettering Kickoff ('13, '14), Kettering ('14, '15), Bedford ('14), Woodhaven ('16), Carver ('16), Einstein! ('16)
Referee: Bedford ('15), MARC ('15, '16), Kettering Kickoff ('15, '16), Kettering District (#1&2: '16), Troy ('16)
Unread 04-01-2015, 16:47
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
Re: 2015 Scouting
With no defense OPR might actually be decent. Huh. I hope FRC tracker still keeps defensive power ranking as a sorting option just for the lulz.
2012 - Engineering Inspiration SFL
2013 - Chairmans SFL, Regional winners SFL
2014 - Engineering Inspiration SFL
2015 - Chairmans GSCR
2016 - Chairmans Rocket City Regional
Unread 04-01-2015, 23:33
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
Re: 2015 Scouting
From the '13 and '14 data I looked at, OPR had a very very high correlation with the new QA ranking system. Chart below shows OPR vs the old "Qualification Score" based on WLT, and the new "QA" system.
Note how events with more matches and fewer teams yield better data (all MAR events were 12 matches, '13 Archimedes was 9 matches, '14 Archimedes was 10 matches)
Team 2590 Mentor [2009-2014]
Team 5895 Mentor [2016-Present]
Unread 04-01-2015, 23:41
Amy33Amy33's Avatar
Amy33Amy33 Amy33Amy33 is offline
Alumni
FRC #2846 (FireBears)
Amy33Amy33 is an unknown quantity at this point
Re: 2015 Scouting
People would still be able to play defense assuming the human players will still be able to throw noodles by Wednesday, or that the robots are good enough stackers to fight over the stuff in the middle. It's not the optimal strategy to be a defense bot in this competition though, as the opportunities for defense are limited, but a good defensive hybrid would probably make it far.
