Go to Post If the world was like ChiefDelphi, people would be more eager to help out, offer advice and encourage each other to better things... not a bad world, that. - MissInformation [more]
Unread 04-01-2015, 11:18
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
roboRIO manual possible confusion
On page 9 of the manual, it reads:
Note The NI roboRIO contains an internal 120 W termination resistor between L (GRN) and H (YEL).
It appears that this "W" means ohm based off of this wikipedia entry:
Where the [symbol] font is not supported, a W is displayed instead ("10 W" instead of "10 Ω", for instance). As W represents the watt, the SI unit of power, not resistance, this can lead to confusion.
Just thought this would be useful to know
Unread 04-01-2015, 11:52
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
Re: roboRIO manual possible confusion
Why didn't they just write out "ohm"?
Unread 04-01-2015, 12:00
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
...and all these years I was thinking W is for Watts - unit for power! One mre change I have to deal with this season!
Unread 04-01-2015, 12:24
jnicho15's Avatar
AKA: Dan
FYI: W DOES NOT mean ohm, it is a font error
Unread 04-01-2015, 13:03
BenDSterling's Avatar
BenDSterling BenDSterling is offline
Alumni, Mentor, Volunteer
FRC #6325 (Reset Robotics)
BenDSterling will become famous soon enough
W still stands for watt. It showed a W in this instance because of a font error. Since the ohm symbol was not supported by the font, a W was put in its place.
just to be clear, W stands for Watt, not ohm.
Lead Mentor: FRC Team Reset Robotics (#6325)
Mentor: FTC Teams #9686 & #10396
Head of AV for Georgia FIRST Robotics
FTC South Super Regional planning committee member
Unread 05-01-2015, 08:56
jnicho15,
Can you show which manual you are looking at for this info? If it is a pdf, it is likely you do not have the greek font loaded and have selected an option where Adobe inserts what it thinks is the correct symbol.
Unread 05-01-2015, 09:58
jnicho15's Avatar
AKA: Dan
Page 9 ofhttps://decibel.ni.com/content/servl...r%20Manual.pdf
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 05-01-2015, 11:30
Yep, it displays as a W.
Unread 05-01-2015, 11:34
Michael Hill's Avatar
We've got one of these on the RoboRIO!
http://m.ebay.com/itm/DALE-25-5-OHM-...-/400251566962
Unread 05-01-2015, 11:39
Have you included a fan as well?
Unread 05-01-2015, 17:51
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Heh - please don't dissipate 120W in roboRIO in any form.
That is a typo/font issue. I'll get a request in to fix this.
Unread 06-01-2015, 08:06
Chris,
Mike linked to a 120 watt resistor with fins on it.
Unread 06-01-2015, 08:57
AKA: Chris Rake
no team (Athena)
Chris,
Yup - pretty sure that's not included with roboRIO.
Unread 06-01-2015, 09:19
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Is it against the rules to smear heat transfer paste all over the RoboRIO?
Unread 06-01-2015, 09:33
AKA: Chris Rake
no team (Athena)
Might make robot inspection interesting.
