Go to Post I think rovers on Mars are way cool but you won't get a crowd of enthusiastic participants cheering as they trudge 150 meters a day. - Andrew Schuetze [more]
Unread 03-01-2015, 21:53
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
CAN Rules
R61 The PDP CAN interface must be connected to the CAN-bus on the roboRIO (either directly or daisy-chained via another
CAN-bus device).
I am reading this correctly that every team is required to use CAN?
Also, R40 defines acceptable positive and negative wire colors, but I see no rules that define CAN wire colors.
Unread 03-01-2015, 22:10
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: CAN Rules
Correct. Don't be afraid. This is a different implementation of CAN than in the past.
CAN wires are signal wires. No signal wires have color requirements.
Unread 03-01-2015, 22:13
Re: CAN Rules
Though the green and yellow wires in your kit will match the coloring on the connectors so that may be a wise choice.
Unread 03-01-2015, 22:18
cgmv123's Avatar
AKA: Max Vrany
Re: CAN Rules
Of course, but virtually the entire control system uses the Red:+, Black: - convention, and you could use White:+, Blue - if you wanted to.
Unread 05-01-2015, 06:27
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
It is a differential pair, not signal and ground. It should be a twisted pair.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 05-01-2015, 07:04
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: CAN Rules
It should be twisted, but does not have to. During beta testing, we were running it using non-twisted to a worse case than using twisted, no issues.
Unread 05-01-2015, 08:56
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: CAN Rules
If you want to twist your own cable...
https://www.youtube.com/watch?v=YAquFszYZ1k#t=75
Unread 05-01-2015, 09:03
Re: CAN Rules
It is not really a "balanced" signal but it is a transmission line. You will need CAN enabled if you wish to use the pneumatics PCM module and turn on your compressor. As always, CAN implementation requires a terminating resistor at each end of the buss. One is provided in the RoboRio (The start of the buss) and another is provided in the PDP (possible end of the buss). If you wish to configure your CAN wiring differently or not use the PDP CAN, then be sure to provide the required termination resistor at the last device in your chain. The majority of CAN problems in the past have centered around the termination resistor.
Unread 05-01-2015, 09:43
Re: CAN Rules
Per R61, PDP CAN is required.
Unread 05-01-2015, 09:54
Re: CAN Rules
Thanks Joe, I forgot we included that. This gives the battery voltage reported by the PDP, right?
Unread 05-01-2015, 10:26
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: CAN Rules
Just to avoid confusion, CAN to the PDP is required (and to the PCM if you use pneumatics), you can still use PWM for motor control.
Former Mentor Team 1771
Former mentor Team 4509
Unread 05-01-2015, 22:13
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Re: CAN Rules
CAN is required to talk with the PDP, but the upside is that you get to learn what all your load currents are!
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 05-01-2015, 22:18
Re: CAN Rules
The battery voltage is monitored by the roboRIO. I assume the PDP requirement is so the DS and/or field can monitor currents.
Unread 05-01-2015, 23:58
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: CAN Rules
Correct.
Unread 10-01-2015, 00:54
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Re: CAN Rules
The 4 ft of green/yellow wire is enough for some short runs for PDP and PCM connections. We plan on using CAN elsewhere as well.
I have not found a good source for green/yellow twisted pair. I know it doesn't have to be the same color, but it's good consistent reminder and it's our school colors. :-)
Does anyone have a good source for the green/yellow twisted pair wire?
Thanks
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
