Go to Post Please understand that teams run things differently for specific and very valid reasons. And, this is OK as long as the students are inspired. - Alexander McGee [more]
Unread 05-01-2015, 13:32
lamk lamk is offline
Ken Lam
FRC #4719
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
Elevator counterweight / constant spring and ability to lift different number of tote
It's easy to figure out the counterweight/constant spring if we have only one single load like tubes used in previous year. Now we have to deal with loads that varies from 8 lb to 50 lb. How can we precisely move the elevator up and down and not fried the motor when holding a position. A linear electrical actuator(worm screw) with no back drive will be nice but we don't have the machine capability.
Unread 05-01-2015, 13:43
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Elevator counterweight / constant spring and ability to lift different number of
Instead of trying to counterbalance, think instead of applying a friction brake of some sort. Try thinking about how you brake a bicycle tire, and see if you can do something like that with your spool that lifts the elevator. Pneumatic would be a great way to generate that braking force without burning out a motor!
2016: Lake Superior WFFA
vps vps is offline
FRC #3021 (The Agency)
vps is an unknown quantity at this point
window motors, snow blower motors, and van door motors (these have the most torque) have worm drive. Use those.
Unread 05-01-2015, 13:51
JDGallagher's Avatar
JDGallagher JDGallagher is offline
AKA: John Gallagher
FRC #1086 (Blue Cheese)
JDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of light
CIMs or mini-CIMs with a RAW box from andymark could work well
Unread 05-01-2015, 13:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
These are 30 watts or less, meaning they are very slow.
Given lack of machining, I agree with the bike brake idea. Otherwise I would say use a steel punch into a hole in a 1st stage gear in the gearbox, pneumatically actuated. 1538 did this with great success in 2013. Requires some precision machining to line up the punch with the hole though.
Unread 05-01-2015, 13:54
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
In the past we've successfully used both bicycle disk brakes and ratchet/ pawl systems to hold loads at position without running the motors.
Unread 05-01-2015, 13:59
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Theoretically couldn't you just design for the heaviest weight that you expect to hold? It wouldn't be ideal but if you think about it, 40 lbs is actually quite a small range so it should work.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 05-01-2015, 14:12
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
Even if you split the difference (0 lbs with no load and 50 lbs full load) and put a 25 lb CF spring your motor would always be working, but at 1/2 the force and 25 lbs should be able to be held by a cim (or bag motor) without too much issue.
Unread 06-01-2015, 00:06
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
The fusee pulley is one solution. It automagically changes its "gear ratio" as the distance traveled increases, so you can use a gearmotor and optimize its lifting speed for the small stack but still have plenty of torque for the tall stack.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 06-01-2015, 00:20
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Why not use a worm drive? We used an Andymark Wormbox in 2011 for our elevator with decent success (we had other racking problems irrelevant of the gearbox) and the RAW Box, as already suggested, could work. We actually used a custom worm drive last year to winch back a really heavily loaded catapult arm, but if you don't have resources to custom build, use a COTS worm gearbox. You can mate with a CIM and get a ton of power out of a reliable box.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 06-01-2015, 00:38
Ken Lam
FRC #4719
We actually use the said gear box for our aerial assist bot to arm a catapult but we have to use a one way bearing and clutch to arm and fire it. For an elevator we want to be able to move up and down at will. However if we only aim for 3 totes and use 2 sims we may be able to get away without a braking system.
Unread 07-01-2015, 10:31
pmangels17's Avatar
AKA: Paul Mangels
If you use a worm you don't have to use a one way bearing, they can be driven both ways without a braking system. They are also a good way to have a compact gear reduction that slows the CIM motors down slow enough to be usable in an elevator.
Unread 07-01-2015, 11:55
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
I have never heard of one of these. Although I am not working with a team this year, I may use this on my own practice design. Seems like it will do the trick.
Unread 07-01-2015, 21:27
Jared's Avatar
Jared Jared is offline
Worm drives CAN backdrive- especially multi start worms. As they wear in, they can backdrive a vibrating and shaking robot.
Unread 08-01-2015, 11:39
pmangels17's Avatar
AKA: Paul Mangels
While yes that is certainly true, depending on the number of starts (or threads) on the worm, the torque required to backdrive is often much higher than will ever be seen in an FRC application, though vibration could foreseeably unwind a worm drive at a very slow rate.
