Thread Tools |
Rating:
Display Modes |
Re: Using the TI LaunchPad from your KoP
Awesome to hear you guys are jumping right in!
I know it's robot season, so there isn't much time left over for personal tinkering, but the community over at 43oh is a really great resource for people starting out. You might want to check out their projects forum for some ideas on what the board can do. |
How can you tell the pioneers? They're the ones with the arrows in their backs. ![]() |
Currently, the output is just driving a pin high (3.3V) or low from the MSP430. Essentially, you can set it in WPILib, and it will get transferred to the HID device on the following USB poll cycle (every 20ms). I'll get my software cohort to elaborate a bit more for you guys on this. The max a single pin can source is 10mA, and the device total is 100mA. When I made the example panels on the wiki, I just used the indicator pins output to directly drive the LEDs. No problems so far. |
If you load one of the three default firmware images it becomes straight forward to set/clear the indicator outputs using the API, which you can then use to drive an LED or other indicator. In addition, we are working on the documentation for the source code provided on our github page, beyond what is commented in the code (including setup instructions). So if you want to do something else with the output data outside of what the 3 preconfigured binaries provide, you can. |
Look in the Joystick class, SetOutput and SetOutputs.
Thanks! I'll take a look at that.
