Go to Post What makes a team great is not what they do during the 6 weeks, but what they do the rest of the year. - davidthefat [more]
Unread 05-01-2015, 14:09
mitchklong mitchklong is offline
None #4859
mitchklong is an unknown quantity at this point
Bottom stacker or top stacker ?
We are considering the problem from two basic perspectives:
1). We stack at the top. This gives you a robot like a fork lift. It can reach out and over things. Some of its challenges are stacking high and falling forward.
2). We stack at the bottom by grabbing an existing stack, lifting it 13", then placing it on an item on the floor (then repeat). You get a bot that resembles an engine lift. Its challenges are that it has to lift heavier loads an ultimately move them into place without them falling over.
Which would work better for this years game ?
Unread 05-01-2015, 14:14
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: Bottom stacker or top stacker ?
2) This seems to support the Keep it Simple Strategy best.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 05-01-2015, 14:18
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
Just depends on how you want to play the game and how well each mechanism integrates with the rest of your robot (drivetrain, other scoring mechanism, etc.). One thing to keep in mind with a bottom stacker is that you must have room to hold onto a box while you lift the others. Certainly not an insurmountable problem, but it may lead to some interesting frame designs.
Unread 05-01-2015, 14:19
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
1.) Allows you to cap off alliance members' stacks with recycle bins to multiply your points.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Yeah my money is with option 2. I'm sure you'll see a little of both, I'm not shooting down the first, but as ^^ said, :Kiss: Keep It Simple Stupid.
Unread 05-01-2015, 14:20
one_each one_each is offline
FRC #4057 (KB Bots)
one_each is an unknown quantity at this point
Engineering is all about trade-offs. As you have noted, both designs have advantages and disadvantages. The next step is to look at your strategy and determine which one will be the better fit. You may even find some kind of hybrid between the two that works best for your team. Don't forget to take into account what your team is able to accomplish in our limited build time!
Unread 05-01-2015, 14:25
aasrobotics's Avatar
aasrobotics aasrobotics is offline
Battery Chargers 4676
FRC #4676 (The Battery Chargers)
aasrobotics is an unknown quantity at this point
The question is if you want to be able to stack totes or recycling cans. Would it actually be possible to use the same rig to grasp both containers even due to their differing size and shape??
Unread 05-01-2015, 14:29
Anything is possible, it is possible. That being said, if you can make your own stacks with totes AND containers, it takes away that task of having to place containers all the way on top of your ally partners stacks. You work. They work. Divide and Conquer.
Unread 05-01-2015, 14:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It looks like there are many possibilities this year, since we have a couple different game pieces, different places to get them from, and different places to put them.
There are several other ideas I've seen and thought of that you didn't mention...such as stacking them onto your robot from either the top or bottom, rather than stacking them onto the platform that way. The totes can be right side up or upside down, and you can use this to let you come up with different ways to collect them, store them, and offload.
It boggles the mind. Have fun!
Unread 05-01-2015, 14:31
None #4859
Yes.
one of the 3 day bots has built a template that fits into the side of both a tote and the handle of a bin. That solution is a top stacker.
For a bottom stacker any mechanism that "pinches" an object from both sides could be adapted to handle either.
Unread 05-01-2015, 14:49
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
some of the containers are going to be tipped over accidentally. Probably should have a container handler that can handle either way.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 05-01-2015, 14:52
RunawayEngineer RunawayEngineer is offline
Master Commander of All Things Tech
AKA: Ches
FRC #0801 (Horsepower)
Team Role: Tactician
RunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to behold
I think that Bottom Stacking is a great way for teams to get a lot of bang for their buck in actuations. 13" of vertical travel is much easier to accomplish reliably than reaching up 6 1/2" - both have the same upper limit for tower height potential due to the rules.
Top Stacking will be essential for big scoring - since it gives you much more freedom to build on the Stacks of other robots/add more than 1 Tote at a time.
I don't think that a Bottom Stacker will be topping the ranks (assuming it doesn't have other tricks up its sleeve) - but it's a slow and steady strategy that could be valuable.
Unread 05-01-2015, 15:03
EdWard3637's Avatar
EdWard3637 EdWard3637 is offline
AKA: Eric Ward
FRC #3637 (Daleks)
EdWard3637 is an unknown quantity at this point
The bottom stacker could work even better if one robot lifts the current stack and another pushes the next tote underneath it. This allows you to build up stacks starting with containers without too much lateral movement.
Unread 05-01-2015, 15:15
Ro`bear Ro`bear is offline
3238 Program Manager
AKA: Robert Verdoes
FRC #3238 (Cyborg Ferrets)
Ro`bear is an unknown quantity at this point
Bottom stackers seem more efficient to me, but the biggest drawback is that they can't help with cooperation as easily. Most designs for bottom stackers can't really accommodate for picking up totes from the step, and would also have difficulty placing on the step.
Unread 05-01-2015, 15:16
EdWard3637's Avatar
AKA: Eric Ward
FRC #3637 (Daleks)
Not necessarily. A design that picks up totes from any part of the lip could easily interact with totes on the step and still lift entire stacks.
