Go to Post One of my early mentors gave me wise words -- when designing a system to compile & analyze information, your first design choice should always include consideration of a stack of 3x5 file cards. - Jaxom [more]
Thread Tools Rating: Thread Rating: 9 votes, 4.56 average. Display Modes
Unread 03-01-2015, 12:34
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
FRC 2015 Field Model Now Available
With the video and manual now public as part of the Kickoff event I have posted the Autodesk Inventor model and a STEP version as follows:
1. On Dropbox - if you asked to be added to the folder the ZIP files are now posted.
2. On A360 Drive
http://a360.co/1tzEJd5 The field in Autodesk Inventor format
http://a360.co/1tzEHlB The field in STEP format
NOTE:
1. Most of the parts are grounded in the Inventor assembly. To move the parts remove the grounded check mark from the various parts.
2. With any STEP file, the assembly is not constrained when imported and the colors may import differently. Use the images in the manual if you want to make the parts the actual color or material
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 03-01-2015, 13:21
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: FRC 2015 Field Model Now Available
Could someone please export a .stl file for those of us who are stuck away from their CAD computers?
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 03-01-2015, 13:40
I am just heading out but will post an STL later today if you have not received one by then.
Phil Dollan
Autodesk Inc.
Unread 03-01-2015, 15:52
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Phil
Great Job don
TEAM 1946-Tamra
Unread 03-01-2015, 16:10
deheer_j deheer_j is offline
FRC #2040 (DERT 2040)
deheer_j is an unknown quantity at this point
thank you very much!
Unread 03-01-2015, 22:15
IocanePowder's Avatar
IocanePowder IocanePowder is offline
FRC #2530 (Inconceivable)
IocanePowder is an unknown quantity at this point
Hi Phil - Team 2530 thanks you for posting these files!
Unread 04-01-2015, 07:34
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Phil,
Thanks for the files.
I get an "Error in reading RSe stream" message and cannot open the Inventor part or assembly files.
I started out with Inventor 2014 SP1 and tried upgrading to SP2 as suggested on the Autodesk website. My current version is Build: 246, Release: 2014 SP2 Update 3.
Any thoughts?
The STEP files worked so I'm good for now.
David
Unread 04-01-2015, 12:38
David,
The file is 2015 version, so it gives you stream error in 2014.
The STEP file is your solution.
Phil Dollan
Autodesk Inc.
Unread 05-01-2015, 14:35
Andy4627 Andy4627 is offline
FRC #4627
Andy4627 is an unknown quantity at this point
Hi Phil,
Its Andy Johnson from Ernest Manning (host location) in Calgary
Met you at the Destination Desktop a few years ago..
not sure which 'drop box' we should look at...
We are an Autodesk School and were expecting to find the Field and KOP in the Autodesk Student Community under the link ....
http://www.autodesk.com/education/co...ended-software
Instead we only find the FTC 2015 Field and KOP (First Technical Challeng),
Please assist?
Thanks
Andy
Unread 05-01-2015, 14:55
Andy,
We are providing the KOP and Field Model in 3 locations.
1. A360 Drive as noted in the links on this thread and the KOP thread.
2. Dropbox
3. The Community webpage. As you found out the FRC links are not yet available (hence the A360 and Dropbox options) but they should be up and running later today.
Phil Dollan
Autodesk Inc.
Unread 05-01-2015, 22:01
MattOz MattOz is offline
FRC #5416 (TaRDIS)
Rookie Year: 2015
MattOz is an unknown quantity at this point
Thumbs up Re: FRC 2015 Field Model Now Available
Thank you so much!!!! We are a rookie team and this helped me see how well my design would perform.
Unread 06-01-2015, 09:46
kprzewodek's Avatar
kprzewodek kprzewodek is offline
AKA: Kevin Przewodek
FRC #0862 (Lightning robotics)
kprzewodek is on a distinguished road
First of all thanks so much for providing the field elements so quickly. That really helps us get a good field visual.
Some suggestions for future year improvements:
1) Provide more accurate modeling of the field elements we have to interact with. I noticed on the totes there is critical detail that is missing...like some ribs and the pocket under the tote on the long sides. That may be important for some teams that need to use that feature to design grabbers.
2) Provide inventor format in older versions....at least the latest supported version. The reason is that many of us are crippled by what our schools are using and they often are behind the latest version. The step seems to read in ok but it would be nice to have in native format.
Unread 06-01-2015, 19:44
Kevin,
Thanks for the feedback. I have passed along the comments on the Inventor release to the FIRST coordinator at Autodesk.
All the best for the upcoming season.
Phil Dollan
Autodesk Inc.
Unread 07-01-2015, 15:27
roach1051's Avatar
roach1051 roach1051 is offline
Go Boilers!
AKA: Jack Roach
FRC #1051 (Technical Terminators)
roach1051 is on a distinguished road
Phil,
I used this link http://a360.co/1tzEJd5 for the field CAD file and got a stl file.
Then I went to http://www.autodesk.com/education/co...ended-software , and find the only things posted for 2015 are FTC files.
Is there an Inventor native format file for the FRC field that is fully constrained available?
Jack
Precision is for amateurs, custom fit is for professionals
Unread 07-01-2015, 15:48
Jack,
Very odd. I will upload again.
In the meantime, use this link from Dropbox.
https://www.dropbox.com/s/1cjdv1jcu9..._2015.zip?dl=0
Phil Dollan
Autodesk Inc.
