Go to Post And please, never scorn a team that makes something outrageous, like a 4 speed 6 motor transmission. - Veselin Kolev [more]
Unread 05-01-2015, 18:26
Pollux Pollux is offline
FRC #1816
Pollux is an unknown quantity at this point
Question Scoring platform construction
Has anyone figured out a good technique for building the practice field elements, specifically the scoring platforms? The 16-degree angles in hardboard are nearly impossible to cut on the table saw in our shop, especially if you like having all your fingers when you're done.
Unread 05-01-2015, 18:44
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: Scoring platform construction
We cut blocks of wood with the 16 degree angle with a miter saw instead. you could stack the blocks together. We found the HDPE plenty strong and spaced out the blocks.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 05-01-2015, 18:49
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
We made a jig that held the hardboard (or the plywood tops) at the 16 degree angle. This worked, except that the uneven pressure on the blade caused it to deflect so we couldn't get a cut as deep as we wanted. If we tried to over compensate, the blade would dig in too deep by deflecting the other direction.
When cutting the plywood tops for the platforms, we clamped a 2 x 4 to the center to keep the plywood straight.
Unread 06-01-2015, 00:03
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
We have a nice SawStop table saw with a huge fence, so the vertical 16 degree angle cuts worked out OK. We had two grown-ups hold the wood for that cut.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 06-01-2015, 00:14
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Totally off topic, but where are people buying HDPE? We have some polycarb but I understand that HDPE can be bought much cheaper.
Are there good local options for buying it in bulk or do you rely on a large-scale provider and then wait for shipping.
Unread 06-01-2015, 14:44
davehansen22 davehansen22 is offline
AKA: Mr. Hansen
FRC #2811 (StormBots)
Rookie Year: 2990
davehansen22 is an unknown quantity at this point
A very effective method for cutting sharp angles on the hard board is to tape the hardboard to a larger piece of lumber (2x4 or 4x4) with a GOOD QUALITY double sided tape. Like this: http://www.woodcraft.com/Product/15D...-x-36-Yds.aspx.
Set your blade to 16deg make several small passes until you have the right depth of cut. Gently remove hardboard, use a butter knife to slide between the pieces.
Unread 07-01-2015, 13:14
Jawilliams2016 Jawilliams2016 is offline
FRC #4991
Jawilliams2016 is an unknown quantity at this point
Does anyone know how tall the scoring platform floor is from the ground to the platform floor?
Unread 07-01-2015, 13:24
adityaag adityaag is offline
FRC #1880
adityaag is on a distinguished road
It's 2". Full specifications are on page 8 of the game manual.
Unread 20-01-2015, 17:26
Underdog_19 Underdog_19 is offline
FRC #4909 (Bionics)
Underdog_19 has a spectacular aura aboutUnderdog_19 has a spectacular aura about
We were lucky to have a company in town, Laminated Plastics, donate a 4'x8' sheet.
http://www.laminatedplastics.com
Unread 05-01-2015, 18:46
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
We managed to quickly, but roughly, build a scoring platform with two (2) sheets of half-inch plywood (at least twenty inches wide, length is up to you), two (2) two by fours, a protractor, and a reciprocating saw.
The edges of the plywood were marked with the protractor (sixteen degrees (16°) for contact with the floor), and the plywood was clamped to a table. A reciprocating saw was used to cut the angle. Extending lines down and perpendicular to the angle were drawn to help keep the saw in line, roughly.
This method was used for both of the long-angled edges and the short-angled edge. Laying your flat sheet of plywood (half-inch thick, twenty inches wide, and your desired length) on top of the two by fours allowed us to have the top of the scoring platform two inches above the ground. Duct tape was used to "attach" the edges to the center piece, but alternate methods are recommended for long term use.
A video of our robot driving over the scoring platform will be posted soon for reference.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 10-01-2015, 19:38
GkornM GkornM is offline
FRC #4296
GkornM is an unknown quantity at this point
We were able to fairly easily cut the angle by attaching the board that needed the angle to on of our steps while the step was standing on end. We then clamped a fence to the top of the up turned step for the appropriate off set for the angle. You then set a circular saw to 16 degrees from the vertical and you run it along the attached piece with another part of the step supporting the saw and giving it an even surface to run along. See attached photos. This was suggested by our swiggity swaggity mentor Sr. Verde.
ID:	17800  Click image for larger version
ID:	17801  Click image for larger version
Unread 17-01-2015, 13:56
MrRoe MrRoe is offline
Coach/Physics Teacher
AKA: Richard Roe
FRC #5014 (Wild Robo-Catz)
MrRoe is an unknown quantity at this point
We bought our HDPE here: http://www.usplastic.com/catalog/item.aspx?sku=42585 ordered and received in 3 days!
Unread 17-01-2015, 14:06
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Is that HDPE smooth texture or "orange-peel" texture? The tote chute calls for smooth, while the scoring platform calls for orange-peel. We decided to cover our scoring platforms with some leftover Regolith that we still have in our shop; the texture feels pretty similar.
Unread 17-01-2015, 14:41
AKA: Richard Roe
We got the smooth. Did not know they were different textures? Where did you find that info at?
Unread 17-01-2015, 16:22
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
The official Q&A.
