Go to Post Einstein 2015 was just a tryout for FIRST's next warehouse forklift operator. - Jay O'Donnell [more]
Unread 18-02-2003, 09:30
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Tank Stearing - 4 wheel drive
Our team has tank stearing with a 4 motor drive system.
Most of our weight is over 2 of the wheels. We found out that the
robot turns better when the weight is towards the front, therefore we are sort of stuck with running our robot with the weight towards the front. Question, If we would have kept the weight in the center of the robot, would the robot turn just as good in both frontwards and backwords configuration.
Unread 18-02-2003, 10:27
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Re: Tank Stearing - 4 wheel drive
With the balance point midway between the front and rear wheels, the machine should behave the same way going forward and backward if all four wheels are alike. With the center of gravity near the center of the robot, you would need more power to turn, though. When turning a tank drive robot with wheels, you are sliding wheels sideways when you turn. By having a forward or rearward weight bias, you need less power to turn and can use "taller" gearing without tripping breakers and/or smoking motors.
Team 1062, The Storm, 2003
Unread 21-02-2003, 21:39
Dick Linn's Avatar
no team (Synergy)
turning
Although I'm not sure just where the center of balance is on our 4-wheel drive 'bot, we put "slipperier' poly wheels in front to assist turning, and pneumatic rubber wheels in back. This may have helped shift the pivot point to approximately 1/3 of the way between the rear wheels and the front. We wanted to avoid drivetrain stress and assist turning but gain a bit from having the extra traction on the ramp. So far, it works very well.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 02-03-2003, 20:42
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
tank steering with 4 powered wheels can be tricky
in 2001 our team had 4 wheelchair wheels for our drive.
our center of gravity was around the middle of the bot, and our wheels were sticky...so we ended up jumping and hopping around when our bot turned.
not good. so in 2002, we designed (patrick) some wicked cool omniwheels, that would be powered and help with manueverability. it was awesome we could spin like nothing else, and we were able to push like one crazy mofo.
Unread 02-03-2003, 21:27
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
We are currently using a four wheel drive with four pneumatic rubber slicks. They get great traction. They are so good on carpet that the robot would jump. They had no problem on the ramp. To fix the jumping we added 2 casters on the back which are raised up and down with a pneumatic actuator. When we need turning on the carpet we push a button and they are down. They don't lift the back tire off the ground but push down enough to reduce the frictional force. Now it doesn't dance, unless we want it to, and we have more than enough traction for hardcore pushing. Yay!
Unread 02-03-2003, 22:06
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
Two words:
Tank treads
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 02-03-2003, 22:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally posted by Clanat
Two words:
Tank treads
Two words:
Can't turn
Unread 02-03-2003, 22:19
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Originally posted by sanddrag
Two words:
Can't turn
Many Words:
Can turn if it is done correctly!
If your gearbox is geared low enough to over come the "side loads" brought on by the treads, you can certainly turn. It is just one more thing that needs to be engineered correctly.
When done well, a tank tread system can be an amazing thing.
Also, there are other ways to get away from side loads on treads.
Just check this out:
Unread 02-03-2003, 22:41
Custom Title
Two words:
Can't turn
The tank treads don't have to be touching on all surfaces. Our weight is centered about 1/3 of the way from the front of our robot, and our track pivots on approximately 7 inches of track, with the rest about 1/32 of an inch above that.
Former Co-Captain
Unread 03-03-2003, 07:15
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
If you want to turn on a tank track, you just have to put in a pivot point. Look at this center wheel we move it up or down to give us the max traction and still turning on a dime.
http://www.valleytech.k12.ma.us/Robo...otAutoMode.JPG
Unread 03-03-2003, 13:41
Originally posted by JVN
Many Words:
Interesting approach, lifting the treads off the floor, makes nice, tight turns, I bet. Oh, BTW, you are missing hardware at #4 just in case you didn't catch it before.
Can't wait to see it in action. Good Luck!
Unread 03-03-2003, 15:03
JVN JVN is offline
@JohnVNeun
Al,
It's not ours!
This drive was made by team 1064. (yay rookies!)
I just lifted the picture from firstrobotics.net to make a point.
I'm sure they appreciate your compliments though!
Unread 04-03-2003, 23:05
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Two words:
Can't turn
Hmmmm...Well, if that's the case, we'd better tell our robot before he gets dizzy.
The editor took some liberties (embellishment)-- we only go 10 fps. and can only stack 7 high
we didn't get the chance to video stacking although that came easy enough--though not as fast as we would have liked.
http://www.fleef.net/robo/robo2rm.rm
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
wheel drive Greg Needel Technical Discussion 3 29-01-2002 12:12
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
