Go to Post Sometimes simplicity is the best feature you can show off. - Koko Ed [more]
Unread 05-01-2015, 19:10
seamushroom seamushroom is offline
AKA: Seamus
FRC #2491 (No Mythic)
Team Role: CAD
seamushroom is an unknown quantity at this point
Non Traditional Tote Stacking?
Is it a viable strategy to try to stack totes so that rather than the totes having their long side parallel to the ground they have it perpendicular? This would allow them to get 2+ levels per bin, and may also cut down on time if it can be pulled off. Totes would have to be stacked in alternating directions so that the lips would be alternating , and not doubled up, ut I think it really could work.
Comments, Questions, Haikus?
Thanks,
Seamus (2491 No Mythic)
Last edited by seamushroom : 05-01-2015 at 22:33. Reason: Should have saiid "Non", not "not"
Unread 05-01-2015, 19:15
BethMo BethMo is offline
FRC #0948 (NRG (Newport Robotics Group))
BethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to behold
Re: Not Traditional Tote Stacking?
Stacking totes on end
Gives you extra height, alas,
Topples with a sneeze.
Unread 05-01-2015, 19:37
ConnorAWD ConnorAWD is offline
AKA: Aaron Doull
FRC #3787 (Wild Robotocats)
Team Role: Student
ConnorAWD is an unknown quantity at this point
Our team has tried to do this, it does not work to any satisfaction. The smallest bump and it is over. Good luck putting a can on top of it (which would be the only reason you would be doing it).
Unread 05-01-2015, 21:55
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
It seems pretty viable if you lean the totes against the backboard. Our test stacks have survived enough to suggest that, if you do it well and design a robot to place a can on that type of stack, it could work.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
