Go to Post Cameras, colors, and tetras, oh my! - galewind [more]
Unread 05-01-2015, 20:06
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Code without Eclipse!
Originally Posted by Spectare View Post
I don't really have any experience with CMake, that's why I wrote a makefile. If I have time I'll learn and submit a pull request with deploy capabilities.
You should, CMake is awesome. WPILib is compiled with it as it is actually a build system generator. Tell it your sources and what you want to happen, and then anyone can compile it using standard makefiles, mingw/msys makefiles, nmake, eclipse, netbeans, qt creator, or another build system.
So does the FRC toolchain just use the armel gcc with links to NI libraries? I haven't delved deep into gcc before but that's what it looked like when I was browsing your repository.
Its a near-stock GCC build for the armel target on linux. The only thing NI-specific is the build of the linux-headers and eglibc library, but are otherwise mostly stock. Before I got everything worked out, I was able to successfully run with pure stock linux-headers and eglibc sources, but that caused some warnings when debugging. GDB and binutils are pure stock, no patches applied. The only patch on GCC is to change the output name of libstdc++ so we can use the latest C++14 features while the system still uses the old version it was tested against: https://bitbucket.org/byteit101/tool...ame?at=default This makes upgrades very easy so we won't be stuck with ancient versions of GCC like Windriver with GCC 3.4.
Watchdog.Kill();
Unread 05-01-2015, 21:07
Spectare Spectare is offline
Team Hacker
AKA: Benjamin Pylko
FRC #3181 (Pittsford Panthers)
Spectare is an unknown quantity at this point
I'm sure I can write off learning CMake as an important programming activity somehow...
So the roboRIO supports C++14? I'll have to update my makefile accordingly if so.
Unread 06-01-2015, 12:37
byteit101's Avatar
The toolchain supports C++14. GCC 4.9.1 supports most of C++14. flag -std=c++1y. Its in the default eclipse config, though there aren't any C++14-specific features in WPILib.
Watchdog.Kill();
Unread 06-01-2015, 15:16
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
That's awesome! So for a novice person to the in-depths of the roboRIO, how would you "deploy" it? Just ssh into it and replace the image with the one generated?
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 06-01-2015, 17:39
fsilberberg fsilberberg is online now
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
By deploy it, do you mean the robot program? Take a look at the ~/wpilib/cpp/current/ant directory. The build.xml there is the ant script we use to deploy the program. Basically, we run a command on the robot to stop the currently running program. We then replace the /home/lvuser/FRCUserProgram and the /home/lvuser/robotCommand files. The FRCUserProgram is the generated code, and robotCommand is the script in the ~/wpilib/cpp/current/ant folder. We then run a command to exec that script. That script is what takes care of setting up stdout to go to a log file and output over netconsole so you can see it in RioLog. The relevant ant task you're looking for is deploy, along with some properties in the build.properties file.
You might also be able to just use ant to call that script, as I'm not sure how make does with ssh and scp.
Unread 06-01-2015, 18:46
Team Hacker
AKA: Benjamin Pylko
Yeah, that's what I meant .
I also just remembered: what does the "-t" option for the robot kill script actually do? I know it says something like start the program as a text program, but I don't know what that means.
