Go to Post Truly listening to the wealth of advice around you is so important. Don't work in a vacuum all season long. - OZ_341 [more]
Unread 05-01-2015, 20:47
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
AM14U2 Platform Upgrades
We are hosting a boot camp build on Sunday and we want to have options for the young teams on how to climb the platform using their kit drive trains.
How our other teams solving this problem?
We are currently going to suggest switching to 6 in wheels and changing the last gear reduction to 14 and 50 tooth gears.
Unread 05-01-2015, 21:35
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Re: AM14U2 Platform Upgrades
I'm worried that the wide config might need 8 inch wheels.
Unread 05-01-2015, 22:05
PurpleInk PurpleInk is offline
Mrs. BoilerMentor
AKA: Betsy Baxter
FRC #1747 (Harrison Boiler Robotics)
PurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant future
I don't think it is a problem. Team Indiana tested both a long and a wide configuration on the scoring platform without any problem.
When assembled per the instructions a 6WD will not bottom out while going over the bump. If you drive along the bump you have the potential for the robot to bottom out. Make sure you check that the wheels are mounted in the correct position for your chosen configuration. I think the problem may occur if you end up mounting the wheel axles in the holes further away from the end plates.
If driving along the bump is something that you want to do with 4 in wheels there is the possibility to bottom out. The chassis is designed to accommodate 6 and 8 in AndyMark wheels.
FIRST Team 1741 - Student 2005 - 2007
FIRST Team 1741 - Mentor 2007 - 2012
BoilerMentor Asks Me to Join His Alliance
FIRST Team 1747 - Mentor 2012 - Present
Ri3D Team Indiana - 2015 - Present
Unread 05-01-2015, 22:23
jeremylee's Avatar
My concern is not crossing, it's driving along whether intentional or accidental.
Unread 05-01-2015, 22:28
ttldomination's Avatar
Sunny
You will also need to order replacement belts in order to slide the wheel back one mounting hole. I'd be interested to see if there's an official recommendation from AM yet on which belt to use.
Actually, on 2nd thought, you could tension the belt as well. So really whatever you want to suggest/the team wants to do.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 05-01-2015, 22:37
Logan Byers Logan Byers is online now
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
https://www.youtube.com/watch?v=2ZbCseo-_ks
http://files.andymark.com/AM14U%20Be...izing_Rev2.PDF
This is from the AM14U, but the hole pattern is identical to the AM14U2.
Unread 05-01-2015, 22:45
Engineering Coach
The video only shows going up the platform straight on. I don't trust that all drivers are going to be able to avoid going up the corner of the platform or riding along it sideways. A dead robot in is unpleasant for your entire alliance. One of their partners could push them off but that will take time that could be used for scoring more points.
- Sunny G.
If you use the wide configuration you could just make it a little longer than 24" and you would have room with the current belts. In the long configuration I think you could cut into the front and back rails and make room for the larger 6" wheels.
Unread 05-01-2015, 23:08
jeremylee's Avatar
Directions for square are for 4 inch. You may be able to cut the ends to fit 6 in wheels in this config also.
Unread 05-01-2015, 23:24
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
- Sunny G.
Since the chassis holes for using 6 inch wheels are the same for the square oriented chassis, the AM14U2 User Guide says to use 151T belts (am-2706).
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 06-01-2015, 10:54
Sunny
I have personally been focusing all my efforts on the long orientation, but yes, cutting slots on the front/back piece is also a good way to avoid having to belt with the belting.
Ah, good catch. I was trying to put the 6" wheels into the first holes that worked, but I guess they're 'supposed' to go one over.
- Sunny G.
1648: 2013-2014
5283: 2015
