Re: Pneumatic Tank Restrictions
Just for clarification. Only White CLIPPARD plastic air tanks are illegal. There are a variety of plastic air tanks that happen to also be white. Those are still legal.
One thing to keep in mind is that the typical compressors used in FRC only have a 9% duty cycle. They get very hot with prolonged use, such as filling a large tank. I would suggest mounting one of the large fans from the KOP next to the compressor to help cool it.
Here's a thought: could the tanks be pressurized while physically detached from the robot (still pressurized by one legal compressor), then installed on the field to comply with transport dimension rules?
I envision a propane-tank-sized accumulator fit to the side of the bot, pressurized off the bot and closed with a valve, then attached to the pressure loop on the bot during the 1-minute field prep. |
#7
Seems to be this is still in the spirit of "On-board the robot" even if the air isn't physically connected to the regulator/valve inlets until it gets on the field. |
#8
Umm, I would say that kind of stretches the meaning of "on-board storage." I would ask at the Q&A to be sure, but a simple fix would be to just keep the tank hooked up to the system at all times, and simply move it outside the robot while keeping the hoses connected. |
#9
Lets just back up for a second here. Why do you want to use one of these viair tanks anyways? The 0.5 and 1.0 gallon tanks are both about 2 lbs heavier than an equivalent storage volume of these clippard tanks. Are you that tight on space that you'd rather add the 2 lbs?
#10
With this year's game I could see using the heavier tank purely because it is heavier since properly placed ballast can be something very useful this season. |
#11
We are always trying to cut weight. Just properly place what you already have.
There must be a rule about exposed tanks. But, since this is not a contact game, maybe not. |
#12
Yes in some games with some designs you need to be extremely conscious about weight, however in this game I predict that I will inspect many robots with a lot of ballast. As an example for the robot we at Team [REDACTED] built in 3 days we added 44lbs of ballast and were still 2.5lbs under weight. In the past there has not been a specific rule about tank placement and I have seen many tanks mounted in less than protected locations. Last year with the tanks that had a tendency to explode there was some increased awareness of tank location but no rule specifically stating that the tanks had to be protected from impact. |
#14
