Go to Post I think everyone just needs to chill out and realize what the real goal of FIRST is. - Koko Ed [more]
Unread 04-01-2015, 20:04
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Eclipse running. JRE installed - still get this error
"unable to find a javac compiler. perhaps JAVA_HOME does not point to the JDK." ...
Unread 04-01-2015, 20:30
afiolmahon afiolmahon is offline
FRC #1218
afiolmahon is an unknown quantity at this point
Re: Eclipse running. JRE installed - still get this error
Make sure that you have installed the Java 8 JDK and not just the JRE. If you did and still can't find it try going to eclipse -> java preferences ->installed JREs and click search and select your C drive and eclipse will find all installed runtimes and you can select the jdk1.8 from there.
Unread 04-01-2015, 20:55
Have you tried the instructions listed for that error under Troubleshooting on this page: http://wpilib.screenstepslive.com/s/...to-the-roborio
Unread 05-01-2015, 13:26
cdewane cdewane is offline
FRC #3381 (Droid Rage)
cdewane is an unknown quantity at this point
afiolmahon has it right, the steps with screenshots are on this page under the heading "Setting up the JDK in eclipse (Java teams only)"
https://wpilib.screenstepslive.com/s...eclipse-c-java
Unread 05-01-2015, 20:53
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
The troubleshoot topic says literally nothing. I've been using eclipse with java 8 for a long time, I'm sure its configured correctly.
Unread 05-01-2015, 23:14
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Where I highlighted the text in my screenshot, what does the text say on your computer?
Note jdk comes with javac, jre dosent.
Unread 05-01-2015, 23:49
JamesD's Avatar
JamesD JamesD is offline
[:o)
AKA: James David
FRC #0330 (BeachBots)
JamesD is an unknown quantity at this point
This is the correct page to review for this issue. Check the section "Setting up the JDK in Eclipse". Read through it carefully as it's very easy to select the wrong folder by confusing JDK and JRE in the folder path. They want you to select the jdk path as it shows in the image (C:\Program Files (x86)\Java\jdk1.8.0_xx) even though the name says jre1.8.0_xx.
As they state "Without this setting you will see error messages about the JRE path not being set correctly."
Unread 28-02-2015, 11:18
bbaggerman bbaggerman is offline
FRC #5616
bbaggerman is an unknown quantity at this point
I had to manually specify the JDK in Eclipse. Go to Window -> Preferences -> Java -> Installed JREs. In my case the only line in the list was for the JRE. Click on "Add..." -> Standard VM and put in the JRE Home directory where the Java JDK resides. On my systems it is "C:\Program Files (x86)\Java\jdk1.8.0_31". Make sure the new JDK line is checked, not the JRE line.
Eclipse is a mess.
Bob
