Go to Post I remember...my first nationals in 1998, when I was in High School, and thinking "Wow, that's really cool. Engineering looks fun..." - Karthik [more]
Unread 05-01-2015, 21:43
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Odd Autonomous Rules
I have reviewed the autonomous rules over and over and something strikes me as being odd.
3.1.2.1 AUTO
During AUTO, points are awarded for ROBOT SETS, TOTE SETS, CONTAINER SETS, and STACKED TOTE SETS. A ROBOT SET
occurs when all ROBOTS on an ALLIANCE move themselves to, and are fully contained by, their AUTO ZONE at the end of AUTO.
A TOTE SET exists if all three (3) Yellow TOTES from an ALLIANCE are fully contained by the AUTO ZONE, but do not meet the
requirements of a STACKED TOTE SET, at the end of AUTO.
A CONTAINER SET exists if any three (3) RECYCLING CONTAINERS are fully contained by the AUTO ZONE at the end of AUTO.
As for scoring, a tote set is 6 points, while a container set is 8.
So if a robot only pushes one tote to the auto zone, would the not receive any points since not all three are in the auto zone? And is each container placed in the auto zone worth 8 points, or does your alliance receive 8 points as long as one container is in the auto zone? If you received 8 points per container in auto zone, wouldn't that be heavily prioritizing the containers if three totes was worth 6, while three containers were worth 18? I feel as if it could be implying that each tote is worth two points, but it says points are awarded for tote sets, and tote sets is defined above. This being said, I am afraid that if it requires all three totes in the auto zone, it would make it a lot harder for simple box on wheels bots to score in auto other than the moving in a robot set, especially in qualification rounds when not all robots will be able to move in auto?
Unread 05-01-2015, 21:46
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: Odd Autonomous Rules
Correct, this year is more of an all or nothing autonomous point system.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 05-01-2015, 21:47
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
You get 6 points if and only if all 3 yellow totes are in the auto zone at the end of auto. The same goes for Container and Robot sets. In my mind this rule is clearly geared towards teams helping rookie box bots make a basic auto for mobility or to push game objects without actually forcing teams to do it.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 05-01-2015, 22:08
FRC #4490
It says a CONTAINER SET is when any recycling container is in the autozone, which is causing the main part of my confusion. Can you get multiple container sets since there are multiple Recycling Containers?
Unread 05-01-2015, 22:16
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
The reason it says "all three" totes and "any three" recycling containers is because there are only three totes on your side of the field, while there are seven recycling containers you can (in theory) use: three next to the yellow totes and four on the step. So it says "any three" to indicate you get the points as long as there are at least three containers in the auto zone, but they don't have to be the three that start out next to the totes. In practice I highly doubt that the containers on the step will ever be use in autonomous, but because they are there the rules can't say "all three" recycling containers and have it make sense.
The scoring for recycling containers and totes works the same way: if you have three in the auto zone, you get the points (8 or 6).
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 05-01-2015, 22:21
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
You are allowed to start the match between the auto zone and landfill zone. This would be the ideal location to attempt to grab one or more recycling cans from the step during autonomous and move it into the auto zone.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 05-01-2015, 22:34
Cyan's Avatar
Cyan Cyan is offline
Vegeta SSJ4
AKA: Sayan Dutta
FRC #2642 (Pitt Pirates)
Cyan is an unknown quantity at this point
I believe you are right, a total of 2 CONTAINER SETs should be possible in autonomous.
Remember that there are 3 CONTAINERs in each alliance zone, as well as 4 CONTAINERs on the step in the middle, for a maximum of 7 possible CONTAINERs for each side. This would mean that dragging the 3 CONTAINERs in your zone would be one CONTAINER SET, and dragging 3 containers from the step to the auto zone would be another. This would mean a total of 8 x 2 = 16 points could be accumulated from containers.
When I first saw the game, I had already thought that the alliance who first grabbed the CONTAINERs on the step would have a decent headstart. This is why I wanted my team to create an autonomous that would claim the game elements in the center for that extra point potential.
FRC #4490
That makes more sense, thank you.
Unread 05-01-2015, 22:35
FRC #4490
According to G7 you can't touch your auto zone or landfill?
Unread 05-01-2015, 22:56
Cyan's Avatar
Vegeta SSJ4
AKA: Sayan Dutta
G7 says that your robot cannot start in the LANDFILL or AUTO zones. However, there is some space between the zones that your robot can legally start in. You can see a visual in 2.1.5 of the manual.
Unread 05-01-2015, 23:06
alopex_rex's Avatar
AKA: Scott Morton
Not quite. The rule is phrased so that there can only be one. If there are six recycling containers in the auto zone, you get 8 points because "a container set exists". There's no per-set scoring.
It would still be really cool to see a robot use one of the containers on the step in autonomous though.
Unread 05-01-2015, 23:18
Cyan's Avatar
Vegeta SSJ4
AKA: Sayan Dutta
"A CONTAINER SET exists if any three (3) RECYCLING CONTAINERS are fully contained by the AUTO ZONE at the end of AUTO." - 3.1.2.1
I believe I get what you are saying, but I still think the wording is ambiguous. I say it is something we should leave for Q&A.
Unread 05-01-2015, 23:43
FRC #4490
Ah, thankyou, I missed that, I was thinking of the staging zone, and assumed that the autozone and landfill touched.
Unread 06-01-2015, 00:08
ConnorAWD ConnorAWD is offline
AKA: Aaron Doull
FRC #3787 (Wild Robotocats)
Team Role: Student
ConnorAWD is an unknown quantity at this point
I might as well list all 4 ways to get auto points.
1. If all 3 robots are in the auto zone when the 15 seconds are over you get 4 points.
2. If 3 yellow totes are in the auto zone when the 15 seconds are over (and with no robots touching it) you get 6 points.
3. If at least 3 containers are in the auto zone when the 15 seconds are over (and no robots touching) you get 8 points.
4. If all 3 yellow totes are stacked in the auto zone when the 15 seconds are over( and no robots touching it) you get 20 points instead of the 6.
Hope that helped
Unread 06-01-2015, 00:15
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
Hope that helped
The "no robots touching" only applies to the STACKED TOTE SET (Your #4).
