Go to Post It's been said before--sports are fine and good, as long as you've got your priorities in the right order for you. - Billfred [more]
Unread 05-01-2015, 22:55
sasha831 sasha831 is offline
Sasha
FRC #4529 (AI Robotics)
sasha831 is an unknown quantity at this point
Red face Omni Wheels with KOP Andy Mark Chassis
Our team wants to create a slide chassis this year, and were considering doing this by switching the 4" KOP wheels provided with 6" omni wheels, and then adding two perpendicular omni wheels in the center, at each end of the frame.
Our question was whether it was possible to connect the omni wheels to the current belt drive system, what interfaces/hubs we would need, and whether or not the belt would interfere with the wheel itself?
Similar to this:
https://www.youtube.com/watch?v=JqJK0E9Jpmk
Theory is when you know everything but nothing works. Practice is everything works but no one knows why. On our Team, theory and practice are combined: nothing works and no one knows why!
Unread 05-01-2015, 23:05
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Omni Wheels with KOP Andy Mark Chassis
If you are using these, the included pulleys will interface. You will just need to make custom spacers since they are thinner than the HiGrips. The belts will not interfere with the wheel due to the pulley flange and the taper of the wheel. For 6 inch wheels you will most likely use the holes specified for the square oriented chassis. The AM14U2 User Guide says to use 151 tooth (am-2706) belts for that.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 05-01-2015, 23:06
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
The Ri3D used the kit frame and drive set up to create a slide drive.
461 Westside Boiler Invasion
45 Technokats
Unread 06-01-2015, 01:16
Sasha
We were planning on using the Vex ones, as we wanted a double wheel, not single. We are open to using these from AndyMark, but they are 5 times as expensive as the Vex, so Vex is prefered.
Yes, oRyon Labs had a slide base, but they used a custom Vex Chassis. Or were you referring to a different Ri3D team?
Unread 06-01-2015, 01:24
Lead Bumper Mentor
AKA: Mike Marandola
You should be able to use the VEX 6 inch omnis. According to this, the VersaKey will not cause issues with the AM pulleys.
Unread 06-01-2015, 01:57
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Video deleted.
Unread 06-01-2015, 02:12
Lead Bumper Mentor
AKA: Mike Marandola
Originally Posted by ratdude747 View Post
Video deleted.
This is the video that was removed. It is an AM14U2 with an 80/20 rail to support their slide gearbox.
Unread 06-01-2015, 14:17
Charger's Avatar
Charger Charger is offline
AKA: Yiğit Korkmaz
FRC #3646 (Integra)
Charger is an unknown quantity at this point
Does anybody know how can we use 4" andymark omni wheels in KoP chassis? Can we just put dualie 4" Omni wheels instead of hi grip wheels or do we need to buy or make special hubs or spacers?
Unread 06-01-2015, 17:59
Sasha
If you use these, then you can just swap them with the regular wheels, however if you want to use these or these, you will need extra parts to interface them to the current belt pulleys
Unread 07-01-2015, 00:26
Lead Bumper Mentor
AKA: Mike Marandola
Are you sure about that? The DuraOmni wheels are significantly wider than the included HiGrips. New spacers will have to be made at the very least.
Unread 07-01-2015, 03:25
Charger's Avatar
AKA: Yiğit Korkmaz
FRC #3646 (Integra)
well , I think using some spacers and hubs will be enough to use 4" dualie plastic / aluminum omniwheels. But what I'm curious about is, the hubs that come with chassis, are they suitable for 4" omni wheels?
Unread 07-01-2015, 06:31
Sasha
The provided hubs are suitable for the cheaper dura wheels, not for the dualie wheels
No, that's a very good pickup, I just did the math, and you have 3.625" of space on each side, while the DuraOmni + 2 pulleys (assuming middle wheel) are 3.78". However, If you only put in the outer wheels, then that becomes 2.89", and so the two outer wheels(Green in diagram) will fit into the chassis fine(with new spacers), while the middle one(red in diagram) will not
Diagram: http://i.imgur.com/oWDiqXO.png?1
So in short, teams can use the DuraOmni with all the default gear for a 4 wheel drive, not a 6 wheel drive
Unread 07-01-2015, 19:44
Sasha
Will the 6" omni's have enough height clearance? They are 37mm wide, while the default Hi-Grips are 25mm wide
Unread 07-01-2015, 19:57
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Sorry we took the video down. It got messed up while downloading. Better Video
This video better shows off the slide drive with the AM14U2.
Edit: My bad that's the same video you linked. I'm still tired from the build...
Unread 07-01-2015, 21:35
Lead Bumper Mentor
AKA: Mike Marandola
What do you mean by height clearance? So it doesn't hit the flanges?
