Mecanum Wheel Speed Reduction
Hi CD,
I would like to know what speed reduction do you reccomand for 6" mecanum with one cim motor per wheel. We used to have 9:1 - 13:1 with 6" wheel in tank drive. |
Re: Mecanum Wheel Speed Reduction
We will most likely go with 10.5:1 which will give us about 10.7 ft/s adjusted.
This is totally contextual, but I look at past successful robots for years with "field dividers" (2010, 2012) that have their speeds posted to try to pick a reduction. We'll likely go 11-12 ft/s max.
In 2013 we used 6" Vex-Pro Mecanums with one CIM per wheel. The gearbox ratio we eventually settled on was 8.45:1. If fact, we're using that robot to determine this years needs.
Here's the formula for vehicle free speed at motor free speed: V = (N*pi*D)/(720*G) feet/sec N is the motor free speed in RPM. G is the motor revs per wheel rev (i.e. includes gearbox and sprocket or pulley reduction) D is the wheel diameter in inches. A rough rule of thumb1 is to multiply V by ~80% to account for various friction forces to obtain vehicle top speed at full throttle. 1originating I believe with JVN. The actual fudge factor depends on your drivetrain design and workmanship. |
