Go to Post Let it be noted in the annals of FIRST history that on this day the game design committee did NOT choose to change, clarify, explain, or interpret ANY PART of the 2010 Manual. - Richard Wallace [more]
Unread 06-01-2015, 02:22
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Mecanum Wheel Speed Reduction
Hi CD,
I would like to know what speed reduction do you reccomand for 6" mecanum with one cim motor per wheel.
We used to have 9:1 - 13:1 with 6" wheel in tank drive.
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 06-01-2015, 02:28
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Mecanum Wheel Speed Reduction
Originally Posted by yarden.saa View Post
Hi CD,
I would like to know what speed reduction do you recommend for 6" mecanum with one cim motor per wheel.
We will most likely go with 10.5:1 which will give us about 10.7 ft/s adjusted.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 06-01-2015, 09:02
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
This is totally contextual, but I look at past successful robots for years with "field dividers" (2010, 2012) that have their speeds posted to try to pick a reduction. We'll likely go 11-12 ft/s max.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 06-01-2015, 15:23
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Hi CD,
In 2013 we used 6" Vex-Pro Mecanums with one CIM per wheel. The gearbox ratio we eventually settled on was 8.45:1. If fact, we're using that robot to determine this years needs.
Unread 06-01-2015, 16:29
Here's the formula for vehicle free speed at motor free speed:
V = (N*pi*D)/(720*G) feet/sec
N is the motor free speed in RPM.
G is the motor revs per wheel rev (i.e. includes gearbox and sprocket or pulley reduction)
D is the wheel diameter in inches.
A rough rule of thumb1 is to multiply V by ~80% to account for various friction forces to obtain vehicle top speed at full throttle.
1originating I believe with JVN. The actual fudge factor depends on your drivetrain design and workmanship.
