Go to Post Thank you FIRST -- thank you, thank you, thank you -- I can't say that enough. We can't say that enough.... Its too bad that more of us don't try. - Aidan F. Browne [more]
Unread 06-01-2015, 10:39
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Re: Robot Size
Originally Posted by Bruceb View Post
We have been having a discussion on the topic of robot set up and transport configuration.
I feel you cannot change from transport to playing config until you are on the field while another mentor thinks you can change while in queue.
The way the manual reads, it says that you have up to one minute to get your robot ready on the field, but anything beyond one minute will result in a "delay of game". I doubt that you will be able to build your robot in queue, as some robots may be extremely large and then putting it on the field would be an issue. G10 states "DRIVE TEAMS are expected to stage their ROBOTS for a MATCH safely and swiftly. As a guideline, ROBOTS should be configurable in fewer than sixty (60) seconds."
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
