Go to Post No, but you have access to the most powerful machine tool of all; a telephone. We had zero machining sponsors, now we've probably had over 30 unique shops run parts for us; All we did was ask. - AdamHeard [more]
Unread 05-01-2015, 22:37
Lemon's Avatar
Lemon Lemon is offline
Builder of Robots
AKA: Andrey (Gooby)
FRC #2383 (Ninjineers)
Team Role: Electrical
Lemon is an unknown quantity at this point
Pneumatic Tank Restrictions
After looking through the manual, I couldn't find any restriction as to the manufacture of pneumatic tanks used for the systems. Specifically, to the best of your knowledge is there anything that would restrict us from using a Viair half gallon or gallon metal tank?
http://www.viaircorp.com/05gallon.html
Unread 05-01-2015, 22:40
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Pneumatic Tank Restrictions
As far as I have read the only restriction on tanks is it must be rated 125 psi or above and they cannot be the White CLIPPARD Plastic Air tanks.
R66
I. Pneumatic storage tanks (with the exception of White Clippard tanks P/N: AVT-PP-41)
R64 All pneumatic items must be COTS pneumatic devices rated by their manufacturers for working pressure of at least 125psi (with
the exception of R66-D).
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 05-01-2015, 22:47
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Originally Posted by orangemoore View Post
As far as I have read the only restriction on tanks is it must be rated 125 psi or above and they cannot be the White Plastic Air tanks.
Just for clarification. Only White CLIPPARD plastic air tanks are illegal. There are a variety of plastic air tanks that happen to also be white. Those are still legal.
Unread 06-01-2015, 10:29
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
One thing to keep in mind is that the typical compressors used in FRC only have a 9% duty cycle. They get very hot with prolonged use, such as filling a large tank. I would suggest mounting one of the large fans from the KOP next to the compressor to help cool it.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 06-01-2015, 10:44
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Further clarification: The specified tanks had failure problems, and that's why they are not allowed. FRC has nothing against white tanks, plastic tanks, or other Clippard tanks.
Unread 06-01-2015, 10:49
I saw a team last year use a large tank. Note: It has to be pressurized with a legal Compressor (check the specifications for compressors). They charged it with an off-bot compressor (heavy duty legal compressor). It took 2-3 minutes to charge the tank.
Unread 06-01-2015, 17:30
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Here's a thought: could the tanks be pressurized while physically detached from the robot (still pressurized by one legal compressor), then installed on the field to comply with transport dimension rules?
I envision a propane-tank-sized accumulator fit to the side of the bot, pressurized off the bot and closed with a valve, then attached to the pressure loop on the bot during the 1-minute field prep.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 06-01-2015, 17:39
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
R70 “Stored” air pressure on the ROBOT must be no greater than 120 psi. No stored air pressure intended for the ROBOT may be located off-board the ROBOT.
So no
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 06-01-2015, 18:03
BryceKarlins's Avatar
BryceKarlins BryceKarlins is offline
Video Production Junkie
FRC #1261 (RoboLions)
BryceKarlins is on a distinguished road
Also, the tank is a part of the robot, therefore has to be included in the transportation configuration.
Unread 06-01-2015, 18:23
seg9585's Avatar
AKA: Eric
Originally Posted by BryceKarlins View Post
Also, the tank is a part of the robot, therefore has to be included in the configuration.
Well it has to be included within the transport configuration dimensions of the robot (28x42x78) ie physically placed inside that perimeter until the tank can be relocated elsewhere when placed on the field. For example, couldn't the tank sit within an area intended for tote intake/processing during transport, then moved to an external area when placed on the field?
Seems to be this is still in the spirit of "On-board the robot" even if the air isn't physically connected to the regulator/valve inlets until it gets on the field.
My FIRST legacy:
Unread 06-01-2015, 18:26
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Lets just back up for a second here. Why do you want to use one of these viair tanks anyways? The 0.5 and 1.0 gallon tanks are both about 2 lbs heavier than an equivalent storage volume of these clippard tanks. Are you that tight on space that you'd rather add the 2 lbs?
Unread 06-01-2015, 19:16
Umm, I would say that kind of stretches the meaning of "on-board storage." I would ask at the Q&A to be sure, but a simple fix would be to just keep the tank hooked up to the system at all times, and simply move it outside the robot while keeping the hoses connected.
Unread 06-01-2015, 19:23
KMeyers's Avatar
KMeyers KMeyers is offline
AKA: Kevin Meyers
FRC #5109 (Gladiator Robotics)
KMeyers has a spectacular aura aboutKMeyers has a spectacular aura aboutKMeyers has a spectacular aura about
You could help reduce the load on the compressor by preloading the tank from an off-board compressor prior to the match.
Unread 06-01-2015, 19:29
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Please see:
R68 Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not
exceed nominal 12VDC, 1.05 cfm flow rate.
Using an off-board compressor while having an onboard one is not legal.
2016: Lake Superior WFFA
Unread 06-01-2015, 19:39
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
With this year's game I could see using the heavier tank purely because it is heavier since properly placed ballast can be something very useful this season.
