Go to Post I tried to make them look at disgruntled as possible. - Katie_UPS [more]
Unread 06-01-2015, 10:48
Bluejackets's Avatar
Bluejackets Bluejackets is offline
Bluejacket Robotics
FRC #5464 (Bluejacket Robotics)
Rookie Year: 2015
Bluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to behold
Ethernet Camera Trouble
We were wondering if we could use last years ethernet camera with this years roboRIO, we just need help on how to get it to work we are a rookie team. Please Help
Thanks
Unread 06-01-2015, 10:52
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Ethernet Camera Trouble
While I haven't tested it yet, have you tried using the same code as last year? It might work the same way.
The alternative is you can use a USB camera, that will probably have a better resolution.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 06-01-2015, 10:53
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Direct connect the camera to a laptop or desktop computer. Configure the network port (ip address, subnet mask) to allow communications with the camera. Change the Camera's IP address to a legal one (a function of your team's number). I believe there is a default IP address for the camera in the libraries.
At that point, you should be able to connect it to the robot's ethernet network.
There are setup guides, depending upon which camera you are using.
Unread 06-01-2015, 10:55
Bluejacket Robotics
Rookie Year: 2015
we are a first year rookie team so we dont have the code from last year
Unread 06-01-2015, 10:59
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Yes it will work without a problem. We have been using the IP camera as an alpha and beta test. What language are you programming in?
Simply connect to the axis camera website using the IP and configure it for your use. Plug the RoboRio into the D-link, then plug the camera into the D-link as well.Try to avoid powering the camera and the D-link on the same VRM.
Although we have done that successfully in practice, we will never have both the 5V camera and 5V D-link on the same VRM in competition.
If you have a specific question on how to grab frames let us know.
You can also use the Axis Config tool provided by FRC (installed with the FRC suite i.e driverstation) if you are unsure how to determine the IP of the camera.
Follow screensteps here: http://wpilib.screenstepslive.com/s/...an-axis-camera
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 06-01-2015, 11:00
Bluejacket Robotics
Rookie Year: 2015
we are using lab view
Unread 06-01-2015, 11:05
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
When opening LabVIEW and looking at the Welcome Screen, click on the Utilities tab on the left hand side. On this tab, you will see the Setup Axis Camera Tool. Open this up and follow the instructions, and your camera will be good to go! If you are planning on using the camera with the dashboard, remember to click on the "Camera Off" button and select "IP Camera" to bring up the live feed!
I'm right 90% of the time, so why worry about the other 3%?
Unread 06-01-2015, 11:07
JamesD's Avatar
JamesD JamesD is offline
[:o)
AKA: James David
FRC #0330 (BeachBots)
JamesD is an unknown quantity at this point
If you are using an Axis camera there there is a tool with the NI software to configure it. You can find it under tools when you open LabView or it may also be on your start menu (should also be able to find it here: C:\Program Files (x86)\National Instruments\LabVIEW 2014\project\Axis Camera Tool).
Use this to configure the camera. It will set the camera for DHCP so it will pickup an IP address automatically and set a username/password of FRC/FRC as well as other settings. Once this is run you should be able to open a web browser and point it to the camera. You may have to set the host name manually to axis-camera for the dashboard and other software to find it.
See https://wpilib.screenstepslive.com/s...an-axis-camera
[Don't follow the manual setting instructions as those are still from last year.]
