Go to Post I trust my life to a 3650 pound rolling chunk of metal every day that, if some silicon failed in just the right (wrong?) way, would splat me pretty quickly, but I have faith in engineering. On the other hand, it doesn't turn me upside down. - DonRotolo [more]
Go Back   Chief Delphi > Technical > CAD
Unread 04-01-2015, 17:44
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
Detailed Tote CAD File
Has anyone found a detailed CAD drawing (preferably in STEP format) of the totes used in this years game? I have seen this site which has been useful but am wondering if there is a more detailed version available. Thanks and have a great season everyone!
Unread 04-01-2015, 17:46
wilderbuchanan wilderbuchanan is offline
FRC #3408 (Killobyte Cubs)
Team Role: CAD
wilderbuchanan is an unknown quantity at this point
Re: Detailed Tote CAD File
open the STEP assembly of game field and copy our one of the yellow totes
Unread 04-01-2015, 18:03
stepan's Avatar
stepan stepan is offline
Programming Captain
AKA: Stepan Subbotin
FRC #4536 (MinuteBots)
stepan is an unknown quantity at this point
If you're using Creo 3.0, or SolidWorks you can use the files that SolidWorks has provided. I'm not sure if Inventor has the ability to open .stdprt and .stdasm files.
You can download the zip folder by clicking on "NEW! FRC SOLIDWORKS Kit of Parts 2015" over at http://www.solidworks.com/sw/educati...gn-contest.htm
Once you unzip the folder you'll be able to access YELLOW-TOTE.sldprt, and GRAY-TOTE.sldprt.
Unread 05-01-2015, 13:56
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
You can download the field model in STEP format using the following link. The totes are included.
http://a360.co/1tzEHlB
NOTE:
With any STEP file, the assembly is not constrained when imported and the colors may import differently. Use the images in the manual if you want to make the parts the actual color or material.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 05-01-2015, 19:20
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
NOTE:
I would just like to point out that the totes in this model are not the correct dimensions.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 05-01-2015, 19:44
Adam,
Please check your Private Messages.
Phil Dollan
Autodesk Inc.
Unread 05-01-2015, 21:06
Bochek's Avatar
AKA: Adam Bochek
When i import the stp into inventor the totes are 16.25 x 26.75 instead of 16.9 x 26.9
Unread 05-01-2015, 23:09
Adam,
As noted, the same 3D tote models are provided to all software vendors.
Can you direct me to the source of the 16.9 x 26.9 dimensions.
Thanks again for your input.
Phil Dollan
Autodesk Inc.
Unread 06-01-2015, 11:27
Bochek's Avatar
AKA: Adam Bochek
I downloaded the STEP files from this link, http://a360.co/1tzEHlB opened them in inventor 2014.
The 16.9 x 26.9 are the dimensions listed in the manual, and what was measured on our actual tote provided in the kit of parts.
2.3.1 TOTES
Each ALLIANCE has access to two (2) types of TOTES; Yellow TOTES (Pantone 109M) and Gray TOTES (Pantone 423M). Each TOTE is
26.9 in. long,16.9 in. wide, 12.1 in. tall, and made of a rigid plastic.
Edit: I'm working on getting pictures of a tape measure on our actual tote.
Unread 06-01-2015, 11:36
Adam,
Thanks. I am following up with the supplier of the 3D tote model to determine which dimensions we should use.
If we need to resize the 3D model it is an easy fix using Derived Parts.
Phil Dollan
Autodesk Inc.
Unread 06-01-2015, 12:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The model is also missing some dividers that extend down from the top edge of the long sides of the tote. You can see them pretty clearly at 3:06 in the following video: 2015 FRC Field Tour
Unread 06-01-2015, 12:37
Bochek's Avatar
AKA: Adam Bochek
Good Catch!
Unread 06-01-2015, 12:44
Good Catch!
I'm not expecting it to actually trip anyone up, since i'd hope most designers would have access to a physical tote... But if you're doing fiddly things with forks down the sides, those dividers would make the tote sit about an inch higher.
Unread 06-01-2015, 16:00
SamCyanide's Avatar
SamCyanide SamCyanide is offline
Apfel πthon
FRC #2067 (Apple Pi)
SamCyanide is on a distinguished road
Does anyone have this model in an .obj, .dae, .3ds or some other non-obfuscated file format?
Edit: Sorry, I did not see the inventor section. I'm all set to go!
