Go to Post There is no offseason. - Jeff Rodriguez [more]
Unread 06-01-2015, 11:57
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Can Mecanum wheels pass the scoring zone?
Originally Posted by alopex_rex View Post
A team we share space with tried driving over HDPE with a mecanum drive. It could drive straight forward with no trouble, and strafing over it wasn't bad either. The main issue had nothing to do with friction: if the drive train went over diagonally, the bump lifted two of the wheels off of the ground, and they could only get off again by flailing around with the wheels.
This is easily accounted for by modifying the strategy and match flow. I don't envision too many times where a Mecanum's diagonal strafe is terribly useful around the bumps in this game. Personally, I would stick with 90 degree angles as much as possible and completely forget field-centric drive.
The cool thing about Mecanums this year - in order to properly orient yourself to the totes that start on the field, just smash into them from an angle where you're already mostly aligned to them. They'll square you up pretty nicely . Then strafing to pickup totes works like a charm.
Unread 06-01-2015, 12:01
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
I would say to go for it. Nice thing about mechanum is that if you run into problems you can always just switch them out for standard wheels of the same diameter and run that way. No need to make major mechanical changes.
Biggest thing I would say is to get your drivetrain built early and into the hands of the students. Driving practice is going to be more important than anything else if you want them to use it as anything more than a tank drive robot. We have ran mechanum for a few years now and the new kids tend to forget about the strafe and rotation abilities until after they have had a lot of practice with it.
Unread 06-01-2015, 13:47
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
My number one advise for any team considering mecanum for the first time is get a drive train done early, like by the end of week two. Get your drivers practicing by the end of week three.
If you can't get that done then switch to 6 wheel tank. You will be much happier.
We have done mecanum before and there is literally no substitute for practice. We already have an old bot in the programmers hands and should be driving next week.
Unread 07-01-2015, 05:07
TheZorcane TheZorcane is offline
AKA: Ido Rosenbaum
FRC #2212 (The Spikes)
Team Role: RoboCoach
TheZorcane will become famous soon enough
Hey all, Thanks for your answer
We decided (As you said here) that we need more resources and time in order to try Mecanum for the first time. So we will probably go with omni-drive ( KOP with omni and two more wheels).
Thank you very much!!
Unread 07-01-2015, 13:16
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
I will say as being last year our teams rookie year, that mecanum is very doable. We had only met for 9 hours a week and execute a successful mecanum drive and hope to work out the bugs this year.
I have attached a file on programming mecanum, but now a days labview included a base code to help get started.
http://www.pobots.com/files/8213/5726/0394/mecanum.pdf
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
Unread 07-01-2015, 22:18
Mecanum Wheel's Avatar
Mecanum Wheel Mecanum Wheel is offline
It's spelled mecanum
AKA: Bengt Ilon
Mecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond repute
Hey Chad. Just for future reference, it's spelled mecanum. It's an easy mistake to make.
You are absolutely right. Mecanum robots controlled by excellent drivers are a thing of beauty.
Unread 08-01-2015, 01:45
josesantos's Avatar
josesantos josesantos is online now
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
We successfully drove over a platform with 8" AndyMark Mecanum wheels on a Nano Tube Chassis. The frame tubing is 3" tall, giving us 2.5" of clearance.
http://youtu.be/HsZNYA6C_f8
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
Unread 12-01-2015, 11:53
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
I wasn't the one putting the last year's Mecanum drive upgrade on this year's KOP, but they were able to put them outboard using existing holes and they never mentioned it being hard in any way. However using existing holes makes the base too low and it will just barely drag on the scoring bumps so we'll be adding some holes to the KOP chassis to raise it up, but we should be running it as-is tonight as a base and electronic board only (No lifting mechanism installed).
They are going to use a Z axis joystick (that took me 10 minutes to find in a back room behind stuff) but I'm thinking that an XBox controller might work better. I guess we'll find out.
Unread 12-01-2015, 11:57
AKA: Chad
Gotta love auto correct. Typed the post from my cell phone. Didn't even catch that it was changing it on me.
Unread 15-01-2015, 11:31
blturner blturner is offline
FRC #5013 (Trobots)
blturner is on a distinguished road
We did mecanum wheels last year as our rookie year. We seeded 15th at Kansas City. They were surprisingly easy to do. If you hit the scoring platform at a diagonal things will be odd. If you try to strafe with your front on the platform and your rear on the carpet it will probably get weird because of the different friction levels. The weight shift of the totes may make it not track in the exact direction commanded. But all that is not too hard to deal with.
We plan on doing them again this year with field centric again as well. I find that fresh drivers do better with field centric. Experienced ones are better with robot centric. I also believe that aligning with mecanums is easier than skid steer for all but the most experienced drivers.
Brian
