Go to Post I include these trivial facts for the sole purpose of confusing people. :p - KarenH [more]
Unread 06-01-2015, 12:37
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Code without Eclipse!
Originally Posted by Spectare View Post
So the roboRIO supports C++14? I'll have to update my makefile accordingly if so.
The toolchain supports C++14. GCC 4.9.1 supports most of C++14. flag -std=c++1y. Its in the default eclipse config, though there aren't any C++14-specific features in WPILib.
Watchdog.Kill();
Unread 06-01-2015, 15:16
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
That's awesome! So for a novice person to the in-depths of the roboRIO, how would you "deploy" it? Just ssh into it and replace the image with the one generated?
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 06-01-2015, 17:39
fsilberberg fsilberberg is online now
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
By deploy it, do you mean the robot program? Take a look at the ~/wpilib/cpp/current/ant directory. The build.xml there is the ant script we use to deploy the program. Basically, we run a command on the robot to stop the currently running program. We then replace the /home/lvuser/FRCUserProgram and the /home/lvuser/robotCommand files. The FRCUserProgram is the generated code, and robotCommand is the script in the ~/wpilib/cpp/current/ant folder. We then run a command to exec that script. That script is what takes care of setting up stdout to go to a log file and output over netconsole so you can see it in RioLog. The relevant ant task you're looking for is deploy, along with some properties in the build.properties file.
You might also be able to just use ant to call that script, as I'm not sure how make does with ssh and scp.
Unread 06-01-2015, 18:46
Spectare Spectare is offline
Team Hacker
AKA: Benjamin Pylko
FRC #3181 (Pittsford Panthers)
Spectare is an unknown quantity at this point
Yeah, that's what I meant .
I also just remembered: what does the "-t" option for the robot kill script actually do? I know it says something like start the program as a text program, but I don't know what that means.
