Go to Post Common sense goes a long way. - Akash Rastogi [more]
Unread 04-01-2015, 23:59
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Acquiring containers from step during autonomous
Originally Posted by wilderbuchanan View Post
Unless some teams develop non wheel robots that can stack a tote every 2 seconds from anywhere on the field ,i don't think it will matter that much. I think teams will target stacking the recycling bins and autonomous because both are worth a lot more.
As noted, this is mostly going to matter to top ranked teams in Elims. Especially at MSC and Champs. The question you have to ask yourself is if you think a #1 or #2 seed is capable of doing more than three 5-6 tote + container stacks. If they are, then you're starving them for points if you can control all 4 of the shared containers.
Also, picking the containers up isn't actually necessary for a denial strategy to work. You just have to get them onto your side of the field. Once they're beyond the step, they're off limits. I wouldn't be surprised to see a specialized auton and mechanism to swipe the two middle containers in autonomous mode and count on winning the race for one of the two outside containers.
Unread 05-01-2015, 12:01
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Presume 3 containers scored atop a stack of 5, each with a piece of litter.
Per stack, that's worth:
5 totes x 2 points ea. -- 10 pts.
5 levels x 4 points / level -- 20 pts.
1 litter x 6 points -- 6 pts.
36 pts.
3 stacks x 36 pts. per stack = 108 points.
Ignoring the additional time required, for better or for worse, presume that 2 containers are taken from the step at some point during the match and the number of totes consumed remains unchanged.
Per stack:
3 totes x 2 points ea. -- 6 pts.
3 levels x 4 points / level -- 12 pts.
24 pts. per stack.
5 stacks x 24 pts. per stack = 120 points.
In many instances, it'll be more efficient for alliances to form more shorter stacks than a few taller ones if containers can be obtained and scored on those stacks. It's easier to make shorter tote stacks and easier to place containers on shorter stacks, as well.
--Madison--
...down at the Ozdust!
Unread 05-01-2015, 13:08
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
keep in mind that starving your opponents of points is of little use especially if you are wasting your own scoring time doing it.
If you can acquire the containers from the step AND score them then you have a winning strategy in my humble opinion.
So if you are aligned with 2 great stackers that can get 3 full stacks and have time left then acquiring the step containers is going to be very valuable.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 05-01-2015, 13:24
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Originally Posted by Abhishek R View Post
There is an exact diagram in the manual that shows hanging over the step is completely ok, so long as you are not in contact with the other game pieces or carpet, I believe.
This isn't what they are asking about. In 2014 zone boundaries were specifically described as the infinite plane extending upwards from the edge of each marked area on the carpet. This year's game manual says nothing about the 3rd dimension of field zones. OP's question is whether or not the air above the landfill/autozone is included as part of each respective zone, or if only the actual carpet is the real zone.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 06-01-2015, 00:50
TomThompson TomThompson is offline
FRC #0847
TomThompson is an unknown quantity at this point
Precisely my question. Definitely needs clarification, but I believe all the indicators are point toward being able to extend over the landfill and auto zones at the beginning of the game.
1. Robots have no limits on x and y dimensions which would make no sense if you can't stretch over those zones.
2. The rules talk about the zone area and not the zone volume.
3. No mention of an imaginary vertical plane which is language used in previous games.
Unread 06-01-2015, 01:07
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Might be a very important question to ask Q and A Wednesday...who is game to do it?
"A genius is just a talented person who does his homework" T. Edison
Unread 06-01-2015, 01:23
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
I agree with you that you can go over, but that's only useful for grabbing the bins at the beginning. It's not like you're going to run an effective defense game with a bar extending 3 feet away from your bot over the step.
Unread 06-01-2015, 12:05
Squeakypig's Avatar
Squeakypig Squeakypig is offline
AKA: Mike Coyle
FRC #2851 (Crevolution)
Squeakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond repute
Since nobody has said it yet:
A container set in autonomous mode states: "A CONTAINER SET exists if any three (3) RECYCLING CONTAINERS are fully contained by the AUTO ZONE at the end of AUTO."
Emphasis mine.
Therefore, it seems you could have 6 containers in your auto zone at the end of auto, you could have 2 container sets.
Max Score Calculations +8.
Unread 06-01-2015, 12:38
SoccerTaco's Avatar
SoccerTaco SoccerTaco is offline
Mentor, Volunteer
AKA: Steve Parham
FRC #3824 (roHAWKtics)
SoccerTaco will become famous soon enough
I'm looking forward to watching an autonomous container-tug-of-war battle...
Unread 06-01-2015, 12:40
RunawayEngineer RunawayEngineer is offline
Master Commander of All Things Tech
AKA: Ches
FRC #0801 (Horsepower)
Team Role: Tactician
RunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to behold
Emphasis mine.
The wording is confusing, but a Container Set either exists or it doesn't - meaning that the score can't be applied more than once. You don't get one for every set of 3.
WARNING - Taking manual lawyering too far below ~~~~
If you did get points for every set that exists, then you get a set for every combination of RCs since there is no requirement for exclusivity. Your points would be the combination where "n" is the number in the zone and "r" is 3. So 6 containers would actually be worth 20*8=160 points.
http://www.mathsisfun.com/combinator...alculator.html
Unread 06-01-2015, 14:04
ScottM ScottM is offline
AKA: Scott Martin
FRC #0001 (Juggernauts)
ScottM is just really niceScottM is just really niceScottM is just really niceScottM is just really niceScottM is just really nice
Rule G7 seems to be very clear that you can't do this.
Unread 06-01-2015, 14:28
byron.h15 byron.h15 is offline
FRC #3626
byron.h15 is an unknown quantity at this point
Originally Posted by SteveGPage View Post
If you are referencing figure 3-8, in <G18>, that is not related to Auton, but interaction with the step.
I believe that because G18 is in the "General Rules" of the game that the rule could apply to Autonomous. However, I understand that the rule is aimed at Teleop because the likelihood of the rule being violated during Autonomous is very low. I do not doubt that the refs will gladly give out the penalty because a team would need to pre-program their robots to violate the rule.
Unread 06-01-2015, 16:49
penguin4130's Avatar
penguin4130 penguin4130 is offline
FRC #4130 (Blue Devils)
Team Role: Team Spirit / Cheering
penguin4130 is infamous around these parts
Post Re: Acquiring containers from step during autonomous
Rule G7 just says you can't be in either zone when placed on the field before the match has started. I'd say autonomous counts as part of the match.
Unread 06-01-2015, 16:55
registered lurker
AKA: Jake McCann
FRC #3501
It's not. If the auto/landfill zones are not the infinite upwards plane then you can start with your robot extended into any legal game area as long as the ground supporting it is not in an illegal zone.
G18 applies at all times during the game, it's not directed at auto or teleop, it's both.
2011-2015: 1678
2016: 846
