Go to Post We don't use fancy tools like that, but we might need some wood glue or something :) - MrForbes [more]
Unread 06-01-2015, 13:05
RenanTroia RenanTroia is offline
FRC #1382
RenanTroia is an unknown quantity at this point
Litter
Is strictly required to put the litter in the recycle container only after it is on the scoring platform? Or I can put the litter inside the recycle container before leave it on top of the grey totes?
And another question, can the robot leave the recycle container near the human player zone, and than the player put the litter directly inside the recycle container?
Unread 06-01-2015, 13:12
BlairHagen BlairHagen is offline
FRC #0852
BlairHagen is an unknown quantity at this point
Re: Litter
I have the same question, the wording seems to say it needs to be placed in a scored recycling container, but the scores are tallied at the end of the match.
There is a large difference between inserting litter into the can with it off of a stack, as that opens a lot of different methods for inserting the litter.
Unread 06-01-2015, 13:15
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Litter
'Snow Problem tackled this very issue and showed us their findings.
https://www.youtube.com/watch?v=sH0G...ure=youtu.be&a
Hi!
Unread 06-01-2015, 13:21
FRC #1382
Re: Litter
but is that legal?
Unread 06-01-2015, 13:22
Taylor's Avatar
AKA: @taylorstem
Re: Litter
Originally Posted by RenanTroia View Post
but is that legal?
If nothing says it's illegal, then it is legal.
Hi!
Unread 06-01-2015, 13:27
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: Litter
Scoring is done at the end of the match, so to me it sounds like what was intended was "in a scored recycling container at the end of the match". meaning if at the end of the match it's in an unscored container, it's not processed litter.
However, I'm not GDC by any stretch, so this is a good one for Q/A and/or an update (which I would have expected today...).
Unread 06-01-2015, 13:33
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Re: Litter
Reading 3.1.2 it is very clear that is only scored by placing it in scored recycling containers.
This brings up another problem. Lets say you have one scored tote and scored recycling container and then insert the litter into the container and LET go so everything is now scored. Now your bot picks up every thing and then places that stack on top of another tote that is currently and LETs go. So the question is; is the litter still counted as scored? I say no because the container became un-scored when the bot picked up the stack.
Yet another can of worms for the Q&A and or refs.
Unread 06-01-2015, 13:42
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Litter
I can solve that by simply saying that nothing is considered "scored" until the end of the match.
Therefore, by your thought process you would not be able to score litter ever.
This is not the case. Litter can go in recycle containers whenever they want in the match, BUT do not count as 6 points unless the are in a Scored Recycling Container.
Remember these are counted ONLY at the end of the match. So if at the end of the match the container and noodle are on a tote on the scoring platform then they count. If the container is NOT scored at the end of the match the the litter is consider UNPROCESSED.
Biggest part is to remember things are only scored at the end of the match
Unread 06-01-2015, 13:46
BenDSterling's Avatar
BenDSterling BenDSterling is offline
Alumni, Mentor, Volunteer
FRC #6325 (Reset Robotics)
BenDSterling will become famous soon enough
Re: Litter
This answer is correct. You can put litter in a recycling container whenever you want.
Lead Mentor: FRC Team Reset Robotics (#6325)
Mentor: FTC Teams #9686 & #10396
Head of AV for Georgia FIRST Robotics
FTC South Super Regional planning committee member
Unread 06-01-2015, 15:09
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Re: Litter
Sorry to correct you. However, to be absolutely fully correct in that thinking, you would also need to ammend all of your above statements throughout, to include "except coopertition set & stack points", which are counted scored as & when they are completed, & after no robot contact of 3 seconds. Coop Sets, may be advanced to stacks any time during the Teleop period.
______________
From THE GAME 3.1.2.2: (Partial & pasted from after Figure 3-2: COOPERTITION STACKS)
Unlike other points, which are awarded at either the end of the AUTO or TELEOP, points for a COOPERTITION SET or
COOPERTITION STACK are awarded instantly upon successful completion. If points are awarded for a COOPERTITION SET and a
COOPERTITION STACK is formed at a later time in the MATCH, the COOPERTITION SET will be upgraded and instead awarded
points for a COOPERTITION STACK. The PLAYER STATION LED strings will indicate to the DRIVE TEAMS when credit has been
awarded for a COOPERTITION SET or COOPERTITION STACK as described in Section 2.2.1: PLAYER STATIONS.
During TELEOP, Yellow TOTES can only score as part of a COOPERTITION SET or a COOPERTITION STACK.
“Support”, for COOPERTITION, AUTO, and TELEOP, is transitive through other TOTES. For example, a Yellow TOTE is “fully supported by the STEP” if
it is resting on top of another Yellow TOTE that is in turn resting directly on the STEP (and thus both Yellow TOTES are “fully supported” by the STEP).
ALLIANCES can earn points for either a COOPERTITION STACK or a COOPERTITION SET in a MATCH, but not both.
_______________
I just didn't want some students and others who have not completely read or fully yet understand the rules of The "Recycle Rush" Game to get the wrong idea(s) based on your statements above is all. As they relate to "Litter" they are, or seem correct, but not overall complete scoring rules.
