Go to Post When in doubt, ask... don't assume (unless you don't mind wasting time/money). - Bill Gold [more]
Unread 06-01-2015, 13:54
G Fawkes G Fawkes is offline
FRC #1290
G Fawkes is an unknown quantity at this point
Teams Using the Kit Frame - What Size Are You Building?
Seems like each the standard frame sizes, long, wide, and square have advantages and disadvantages.
The wide configuration only gives a few inches for permanently mounted exterior elements in the direction of travel. So it seems they would need to be added on the field.
The long configuration has more room for external elements but seems like it could be unwieldy in the tight confines of the field.
The square configuration seems to be good balance between mobility and attaching elements but there are more cuts and belts to be ordered.
Any thoughts?
Any other considerations - will any of the standard frames be able to drive over the scoring platform?
Si Se Puede
