Go to Post There should be no teams yelling "robot". - RoboMom [more]
Unread 06-01-2015, 16:22
falcons3008 falcons3008 is offline
FRC #3008
falcons3008 is an unknown quantity at this point
Need some Encoder help.
Hi,
I'm new to LabView. Could anyone guide to towards an example of a working wheel encoder code? Last year we've tried to use them but ran into some errors. Any help is appreciated!
Unread 06-01-2015, 17:10
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Need some Encoder help.
In LabVIEW if you go to menu bar Help --> Find Examples then go to FRC Robotics --> roboRIO --> Sensors --> Encoder you will find an example project with plenty of documentation. This would be the best place to start.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 06-01-2015, 18:08
FRC #3008
Thank you
