Go to Post Multitasking is a myth. - DonRotolo [more]
Unread 06-01-2015, 17:56
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
System out println
In NetBeans, the build would never finish and messages would be sent to the output stream in session.
In Eclipse, the build stops.
Where do the system.out.println messages go?
The only thing I thought would work would be DriverStation -> Messages tab (or log tab) but both are empty
Unread 06-01-2015, 18:21
Re: System out println
http://wpilib.screenstepslive.com/s/...console-output
Unread 07-01-2015, 08:39
afiolmahon afiolmahon is offline
FRC #1218
afiolmahon is an unknown quantity at this point
It may also be convenient to switch the java perspective to default when eclipse opens if you are just doing java programming since it has all of the tools that you will want instead of having your window cramped by the C++ views, java perspective has the RIOlog (robot console output) view shown by default if you have the plugins installed. (Preferences -> General -> Perspectives -> select java from list -> make default -> apply)
Unread 07-01-2015, 08:54
Team118Joseph's Avatar
Team118Joseph Team118Joseph is offline
The guy that did the lighting
AKA: Joseph Foster
FRC #0118 (Robonauts)
Team118Joseph will become famous soon enoughTeam118Joseph will become famous soon enough
The driver station log is for lower level output. It will tell you the code couldn't load or LabView failed to start.
FRC Countdown Website: http://frccountdown.hosthorde.net/
FRC Countdowns App: https://play.google.com/store/apps/d...h.frccountdown
Unread 07-01-2015, 17:56
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
The riolog is completely empty... heres the code
    int tick = 0;
    public void disabled(){
    	while(isDisabled()){
    		System.out.println(tick++);
    		System.err.println(tick++);
    		Timer.delay(k_updatePeriod);
Unread 07-01-2015, 21:56
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
I've only gotten the riolog to work when I have the rRIO plugged in via USB.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 08-01-2015, 09:35
AKA: Brad
#0190 ( Gompei and the Herd)
Getting RIOlog (NetConsole) depends on the correct subnet mask settings on your computer. If you use DHCP and the router setup tool, it should set everything correctly. If you do it yourself, make sure you are using 255.255.255.0 as the subnet mask or you won't see anything.
Brad Miller
Robotics Resource Center
Unread 08-01-2015, 23:05
thetonio96 thetonio96 is offline
FRC #4635 (Eugenio)
thetonio96 is an unknown quantity at this point
So, RIOlog will work with this:
System.out.println(Some message);
System.err.println(Some message);
or do they use another function to print?
Unread 08-01-2015, 23:18
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Yep, we redirect standard out and standard error to netconsole, which is what riolog reads.
