Go to Post Because nothing says safety like carrying a 150lb robot across a field covered in golf balls. - Kevin Sevcik [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 06-01-2015, 18:49
Re: 2015: Year of the Mecanum
Originally Posted by Tom Line View Post
After all your meCHanum motor set speeds are calculated, mix in a component from the gyro useing a PID.
My interpretation of the above is:
1) calculate the 4 motor speeds using the X and Y translation commands
2) calculate the motor speeds for rotation using the output from a PID
3) add the the corresponding speeds from (1) and (2).
Wouldn't it be more straightforward to compute the 4 motors speeds just once directly from the X, Y, and rotation commands?
BTW, what's the significance of the CH in caps?
Unread 06-01-2015, 21:09
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
What I was thinking was a way of dealing with imperfect results from mecanum, i.e., if simply using WPILib's mecanum drive function results in the robot turning when it's supposed to be straight strafing. When the driver is trying not to rotate (the "rotate" value would be zero), store the current gyro heading. Then have a PID controller that tries to maintain that gyro heading, by setting the "rotate" argument for the function. So the PID would find the value that counteracts any undesired rotation caused by mechanical issues.
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 06-01-2015, 21:11
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
This is exactly what we did in the past for our mecanum drive, and it worked wonderfully. We didn't have to obsess nearly as much about perfect weight distribution.
Unread 06-01-2015, 21:35
See attachment
Unread 06-01-2015, 21:42
alopex_rex's Avatar
AKA: Scott Morton
Nice chart--That's exactly what I was trying to describe!
Unread 06-01-2015, 21:47
forbes's Avatar
forbes forbes is offline
Software developer
AKA: Evan Forbes
FRC #3507 (Ubotics), 694 (StuyPulse)
forbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to behold
See attachment
Thanks, that diagram is helpful.
Unread 08-01-2015, 13:28
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
See attachment
Wouldn't another option be to treat the feedback loop as the "rate controller" for the yaw axis? The rotation command from the joystick would be sent to the yaw controller. If it the command is zero then it will work as described in the attachment. If the command is greater than zero, then the controller will allow for more predictable rates of rotation based on the joystick command.
I believe this is how yaw control is managed on most RC Multicopters.
Unread 08-01-2015, 14:16
What you've described1 would work; but if you're trying to hold position, it's best to close the loop on position, not velocity.
1 ... http://www.chiefdelphi.com/media/papers/download/2796 ...... http://www.chiefdelphi.com/media/papers/2390
Unread 08-01-2015, 14:28
Saberbot's Avatar
AKA: David Ingraham
That makes sense. Thank you for creating these great resources.
