Go to Post Just because a robot looks good and just because it is very well made does not mean that students were not involved in creating it. - Ryan Dognaux [more]
Unread 06-01-2015, 18:34
jreneew2's Avatar
jreneew2 jreneew2 is online now
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Exclamation CANJaguar error with 2015 C++ port sendMessage
Hello again!
I have another error with the CANJaguar code when enabling the robot. All of our code compiles and deploys successfully, however, when we enable the robot our driver station spits out this error
Error on line 492 of CANJaguar.cpp: sendMessage
	at /home/lvuser/FRCUserProgram() [0x17088]
	at /home/lvuser/FRCUserProgram() [0x17250]
	at /home/lvuser/FRCUserProgram() [0x187e8]
	at /home/lvuser/FRCUserProgram() [0x16b64]
	at /home/lvuser/FRCUserProgram() [0x1d9b4]
	at /home/lvuser/FRCUserProgram() [0xf754]
	at /home/lvuser/FRCUserProgram() [0x134f4]
	at /home/lvuser/FRCUserProgram() [0x29f90]
	at /home/lvuser/FRCUserProgram() [0x30e54]
	at /home/lvuser/FRCUserProgram() [0xfdd8]
	at /home/lvuser/FRCUserProgram() [0x155b4]
	at /home/lvuser/FRCUserProgram() [0x1bbfc]
	at /home/lvuser/FRCUserProgram() [0xfee4]
	at __libc_start_main
And I went to look at CANJaguar at line 492 and this is the function:
void CANJaguar::sendMessage(uint32_t messageID, const uint8_t *data, uint8_t dataSize, int32_t period)
	int32_t localStatus = sendMessageHelper(messageID | m_deviceNumber, data, dataSize, period);
	if(localStatus < 0)
		wpi_setErrorWithContext(localStatus, "sendMessage");
Do you guys have any ideas on what this error actually is and how we could fix it?
Thanks,
Drew
Unread 06-01-2015, 18:37
Re: CANJaguar error with 2015 C++ port sendMessage
Have you updated the Jaguar to v109 firmware? Have you checked using the roboRIO webdash that the roboRIO can see the Jaguar you are trying to talk to and that the ID is what you expect?
Unread 06-01-2015, 18:41
jreneew2's Avatar
AKA: Drew Williams
Yeah, we have updated all of the jags to v109, however we cannot see the jags in the roboRIO panel. It only shows the PDP and the PCM. We have the roboRIO as the start of the CAN network and the terminator as one of the jags. We also have set the PDP terminator jumper switch to off, so it should be able to detect the jags after the PDP.
Unread 06-01-2015, 19:23
If they don't show up in the webdashboard they won't work in your code either. That's the issue to solve first. It sounds like the most likely causes would be your convertor between the twisted pair and RJ connector is not wired correctly or your termination is not correct.
Unread 06-01-2015, 19:48
jreneew2's Avatar
AKA: Drew Williams
Thanks! I'll try that. Our meeting is over today so I don't have the robot on me at the moment. (I wish we could afford some talon srx's right now!)
-Drew
Unread 08-01-2015, 00:14
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
It was a wiring issue with the JAGs.
Thanks for the help.
