Go to Post FIRST is aimed at those girls on your team. They don't know anything about mechanics, or electricity, or programming, or machining. They have no interest in it, either. They're perfect candidates for FIRST. - Madison [more]
Unread 06-01-2015, 20:08
M. Mohis's Avatar
M. Mohis M. Mohis is offline
FRC #5148 (New Berlin Blitz)
M. Mohis is an unknown quantity at this point
H-Drive Question
We were discussing the pros and cons of H drive (4 omni's in tank and one in the middle sideways) and someone brought up that you couldn't do H drive in a U shaped chassis (no front plate). Thoughts?
Unread 06-01-2015, 20:17
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Re: H-Drive Question
How far into the base is the opening? If it's less than halfway into the robot then I don't see any issues with an H drive. If it's more than that then you might have some issues, not only with the slide drive but with general frame stiffness.
Unread 06-01-2015, 20:36
BryceKarlins's Avatar
BryceKarlins BryceKarlins is offline
Video Production Junkie
FRC #1261 (RoboLions)
Team Role: Electrical
BryceKarlins is on a distinguished road
With slide ("H") drives, it's not so much that the center wheel is in the middle of your robot; it's that the center wheel is under your center of mass. If your center of mass is in front, or behind the center wheel, you'll find yourself rotating slightly when you try to strafe.
So, teams that hold the totes in front of their robot will end up in trouble unless they do some maths.
Unread 06-01-2015, 20:39
M. Mohis's Avatar
Currently the U is almost exactly half the base of the robot. But what if we were to put an omni at both the end of the U and the end of the actual robot? Would that reduce weird rotation?
Unread 06-01-2015, 20:41
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
In what direction would you rotate? Away from the mass?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 06-01-2015, 20:50
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
You could do two sideways wheels halfway along the sides of the U shape.
Unread 06-01-2015, 20:56
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Anyone have experience using a gyro to compensate for a center wheel offset from the center of mass?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 07-01-2015, 17:16
NewKid123's Avatar
NewKid123 NewKid123 is offline
FRC #2838 (EagleBots)
NewKid123 is an unknown quantity at this point
What are the pros and cons of and and cons of an H-Drive system? Anybody have any ideas about the pros and cons of an H-Drive system?
Unread 08-01-2015, 07:27
kartikye kartikye is offline
AKA: Kartikye Mittal
FRC #4817 (One Degree North)
Team Role: Driver
kartikye is an unknown quantity at this point
Pro:
Maneuverability
If it fails, you now have a tank drive
Cons:
Bit more expensive
Bit more complex
Unread 08-01-2015, 08:56
eghazal eghazal is offline
FRC #0503 (Frog Force)
eghazal is on a distinguished road
How viable would an X drive be when used with a U shape Chassis?
Unread 08-01-2015, 09:13
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Our team did an offseason drive where the omni wheel was all the way at one end, so it had to compensate substantially in order to strafe straight. We used a gyro and managed to get it to strafe, but strafing was probably only 5 ft/s and we didn't stay with it long enough to get it to go really straight sideways. All we did was a simple proportional controller: we added an amount of turning to the joystick inputs / inverse kinematics equal to the gyro error times a tuning constant. Conceptually it isn't very complicated.
One of the things that does complicate life is that your strafe wheel isn't going to give you the same rate of angular acceleration as the drive does when it tries to spin the robot. That's what made our strafing a little shaky. I think that can be accounted for, but if those angular accelerations are different enough, it might take something fancy to really smooth things out.
If the center wheel was offset only somewhat from the center of mass, those problems get smaller, of course, and maybe you'd get by just fine with the simple proportional gyro feedback loop.
Unread 08-01-2015, 09:56
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
what will that center wheel to do robot balance when you are half way up the bump?
Seems it will get pretty wobbly.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
