Go to Post To me, every robot is a moving mechanical art form, a sculpture made of aluminum, motors and gears, and I think that soon we will be seeing those art forms involved in some of the most fantastic robotic "dances" that any of us have ever seen - DougHogg [more]
Thread Tools Rating: Thread Rating: 19 votes, 5.00 average. Display Modes
Unread 06-01-2015, 20:47
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
Re: Errors with install of Eclipse
We have the same problem. After trying in vain to make it go away we just decided to ignore it. Everything appears to work just fine anyways. We're actually not certain if the code is actually building when we say "build project", or just running the error checkers and then failing with the "gcc not in path" errors before it actually compiles. Either way, it builds when we deploy, so it doesn't really matter.
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 07-01-2015, 09:34
DarthCoder DarthCoder is offline
FRC #4309
DarthCoder is an unknown quantity at this point
If it's not showing up then check to make sure the compiler was even installed correctly. I tested out another install and found the same thing that other people here have said. The GCC not found error can be ignored if you're only developing for RoboRIO and don't plan to use your Eclipse install for desktop development also.
Unread 07-01-2015, 18:46
WhipeeDip WhipeeDip is offline
Programmer
AKA: Elliot
FRC #4139 (Easy as Pi)
WhipeeDip is an unknown quantity at this point
Alright, I got a couple programs running on a testbed. It seems the g++/gcc errors can be ignored.
Unread 08-01-2015, 01:11
MHSrobotics2853's Avatar
MHSrobotics2853 MHSrobotics2853 is offline
Mililani Robotics
FRC #2853 (Trobobots)
MHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really nice
We had this problem too.
Go to Window>Preferences>C/C++>Build>Settings
Under Settings, go to the Discovery tab. There will be an entry called "CDT GCC Built-in Compiler Settings". Click it. The box below (Language Settings Provider Options) will have a text box with text like "${COMMAND} ${FLAGS}..."
Append "arm-frc-linux-gnueabi-" to the beginning. Press "Ok".
Screenshot below:
