Go to Post When our arm "spontaneously combusted in the middle of the field", your team was the first to offer assistance to help fix it. - KTorak [more]
Unread 05-01-2015, 00:42
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Transport Configuration: Question
Rules G10 and G11 Reference the assembling and disassembling of a robot into and out of transport configuration before and after matches. We know that we can take appendages off of our robot and put them on.
While they are off, I would assume, but am unsure, that they have to be in compliance with the Trans. Con. Dimensions of 28/42/78 (So essentially your robot and all parts added or removed when off of the field have to be able to fit into a box this size.) Can someone validate that?
This would mean that any horizontal extensions that are not telescoping, cranked, etc., but were instead rigid would have a maximum length of 78 inches due to the height dimensional restrictions while carrying them off field even if not used as a height piece to be used on the robot. Is that correct? Do I need to clarify?
Essentially, you cant carry around a pole in greater length than 6 feet 6 inches and bolt it onto your robot.
Unread 05-01-2015, 00:49
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: Transport Configuration: Question
Correct except the maximum length would actually be:
sqrt(42^2+28^2+78^2)=92.91"
due to being able to use the diagonal length from opposite corners
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
Yes, all parts of the robot must fit within the Transport Configuration of 28"x42"x78". You can use items to secure parts together to ensure they fit and stay in the Transport Configuration (i.e. zip tie one mechanism to another, this was shown as an example in the field videos).
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 05-01-2015, 00:50
Ah, true true. Good catch.
Unread 06-01-2015, 22:15
Teammattchew Teammattchew is offline
FRC #3277
Teammattchew is an unknown quantity at this point
Could you tweak these Specifications? or is it impossible to have a Square chassis for the robot larger than 28" by 28"?
such as having a 29" by 41" base for example? as long as the Transport configuration does not excede a 70" perimeter?
Unread 06-01-2015, 22:40
pwnageNick's Avatar
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
No this would not be legal. It does not say anywhere in the rules that it is based on perimeter. It says that it must fit in the listed size.
*My answer is not official, so if you really want this officially answered, consult the Offical Q&A.
Unread 06-01-2015, 22:51
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Well, this is a theory, but could this year be the return of the flop bot? It would afford you a little bit more space I suppose.
Academic Student (Forever)
Unread 06-01-2015, 23:46
FRC #3277
if i knew what a flop bot was i suppose
Unread 07-01-2015, 01:15
Flop Bot: Reference 16 (2008), 67 (2004, 2005), and 71 (2002). Robot that starts on one "end" and falls over to get to its primary drivetrain (and a very large base) when the match starts.
Also see http://beyondinspection.org/post/104...r-famous-flops for a better description.
