Go to Post This is a high-energy sporting event, not a piano recital. :) - Alan Anderson [more]
Unread 06-01-2015, 20:14
TeamMarcies TeamMarcies is offline
FRC #4777
TeamMarcies is an unknown quantity at this point
Packages/Importing problem with FRC Java
So currently I am trying to use the following VALID java statement:
public Executor executor = Executors.newSingleThreadExecutor();
It requires these two imports:
import java.util.concurrent.Executor;
import java.util.concurrent.Executors;
which require this package:
package java.util.concurrent;
Which isn't found according to Netbeans but is found when I am working with a default java project.
Is this simply not allowed to be used?
I am wanting to use threads in autonomous mode and through that, use Executors that will allow threads to be placed in queue so I can have them executed in the order I have threads be executed in.
Also, are threads allowed to be used?
Unread 06-01-2015, 20:17
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Packages/Importing problem with FRC Java
Is this code for the roboRIO, and if so, how did you set up your project for Netbeans. If you manually set up the project for Netbeans that might have something to do with it.
Unread 06-01-2015, 20:24
FRC #4777
We are using the new 2015 roboRIO.
I've been programming for the team for 2 years and I've just decided to go ahead and clean up our messy code and start using threads to make things easier.
I have set up the project properly.
File -> New Project - > Java FRC -> IterativeRobot
I know it's working because it's recognizing the FRC java API which I am knees deep in with the code. It's just this problem where I can't seem to import a java utility I need for threads.
Unread 06-01-2015, 20:43
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Just use the command-based template. No reason to rewrite the wheel.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 06-01-2015, 20:45
Dartmouth 2020
AKA: lopsided98
Are you using Netbeans? Netbeans is not officially supported anymore, so I suspect you are either trying to use the 2014 plugins or you have something wrong with how you tried to integrate the 2015 API into Netbeans.
I would try using Eclipse to test and make sure your code works in the official environment.
Unread 06-01-2015, 20:51
Dartmouth 2020
AKA: lopsided98
I also recommend using the command-based system. It gives you a lot of the advantages of multithreaded code without worrying about race conditions, deadlocks and other threading weirdness. You will also be able to get more help from other teams.
Unread 06-01-2015, 20:52
FRC #4777
Alright, thanks!
I'll start transitioning to Eclipse and let you know the results.
Unread 06-01-2015, 20:54
Dartmouth 2020
AKA: lopsided98
You've probably already seen this, but in case you haven't, this will help with the installation and setup: http://wpilib.screenstepslive.com/s/...eclipse-c-java
Unread 06-01-2015, 23:09
FRC #4777
Yep! Eclipse did the trick. Thanks guys. I'll be sure to check out the command-based programming - it seems neat.
Just one quick question: Am I able to do a while(true) loop in a thread and have it persistently be doing something or will it crash the network/roboRIO?
Basically what I'm doing here:
public void run() {
        R.autonomousCounter = 0;
        while (true) {
            if ((Math.floor(R.autonomousCounter / loopsPerSecond)) < seconds) {
                if (forward) {
                    theRobot.drive(-robotDriveSpeed, gyro.getAngle() * gyroModifierSpeed);
                }else if (!forward) {
                    theRobot.drive(robotDriveSpeed, gyro.getAngle() * gyroModifierSpeed);
            }else{
                break;
        theRobot.drive(0.0, 0.0);
Unread 06-01-2015, 23:16
AKA: Spencer Lanman
public void run() {
        while (true) {
                if (forward) {
            }else{
                break;
Just do it this way:
public void run() {
        while ((Math.floor(R.autonomousCounter / loopsPerSecond)) < seconds) {
            if (forward) {
I still wouldn't be worrying with threads though.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 06-01-2015, 23:17
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Add
Timer.delay(0.005);
at the end of your loop and you should be fine.
Unread 06-01-2015, 23:46
FRC #4777
Greatly appreciate the help guys, thanks!
