Go to Post I design gears and gear boxes for a living. I am HAPPY to write a check and have a solution in mailed to me. - Joe Johnson [more]
Unread 06-01-2015, 23:51
carrud carrud is offline
AKA: Clark Rudder
FRC #2637
carrud is an unknown quantity at this point
When are penalty points assessed?
When are penalty points assessed? Are they assessed immediately, and therefore a team penalized early potentially looses zero points.
Unread 07-01-2015, 00:07
ConnorAWD ConnorAWD is offline
AKA: Aaron Doull
FRC #3787 (Wild Robotocats)
Team Role: Student
ConnorAWD is an unknown quantity at this point
Re: When are penalty points assessed?
I do not have the rule book right in front of me, but I understand it as being totaled at the end, as it said the only thing counted immediately is Co-op/Autonomous.
Unread 07-01-2015, 00:22
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
From the wording of the rule it is assigned at the time of the offense and only counts at that point in time.
3.1.3 Penalty Assignment
Upon a rule violation, a FOUL will be issued and six (6) points will be decremented from the offending ALLIANCE’S score.
The minimum score for an ALLIANCE in a MATCH is zero (0).
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 07-01-2015, 01:20
I see what the rule says. However, what I think actually happens in software is more like:
"Current score is X. X-6. Wait, that's <0, so I just display 0. OK, score is now up to 0, keep showing 0. NOW score is positive. Wait, another -6. But the score is still positive, so keep showing the score."
You don't lose zero points for an early foul. You lose all the points assessed, at some point--unless you're below zero--so the outlined situation is more reasonable.
Back when this sort of foul stuff was more common, they'd just show the score, then knock off the points at the end.
Unread 07-01-2015, 21:08
AKA: Clark Rudder
FRC #2637
It is still not perfectly clear exactly when the points will be assessed. Potentially immediately and in order of other scores being received. However, it seems like it could be argued otherwise.
Anybody have specific knowledge/info?
Unread 07-01-2015, 21:32
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
While the evidence is not concrete, looking at yesterday's blog post about the new match display, it shows on the final score screen how many foul points each alliance had subtracted from their score which leads me to believe that the points are subtracted at the end of the match.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
