Go to Post Too many people have worked too long and too hard to have the selfish actions of one person derail our teams reputation because they want to vent online. - Koko Ed [more]
Unread 06-01-2015, 17:39
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Mechanum with XBox Controller
As of now our team has the XBox controller working using ArcadeDrive. But we now want to use mechanum wheels.. I have an okay understanding of how to do this with a joystick using x, y, and twist but how do I do it with an XBox controller. I don't even know how I would begin to structure the code.
ANY help would be GREATLY appreciated! THANKS!
Unread 06-01-2015, 18:31
cyborgstx's Avatar
cyborgstx cyborgstx is offline
AKA: Lydia
FRC #3335 (Cy-Ranch Cy-Borgs)
cyborgstx is an unknown quantity at this point
Re: Mechanum with XBox Controller
What template are you using? I could give you Iterative sample code.
Unread 06-01-2015, 23:07
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Something like this:
float gyroAngle = 0.0; // we don't have a gyro connected
myRobot->MecanumDrive_Cartesian(stick.GetX(), stick.GetY(), stick.GetZ(), gyroAngle);
Brian K
Team 1225 Robotics Mentor
Unread 07-01-2015, 08:33
afiolmahon afiolmahon is offline
FRC #1218
afiolmahon is an unknown quantity at this point
I would just pick one of the sticks for your X and Y axis, and then a good replacement for the joystick twist would be using the analog triggers on the xbox controller. If you need Axis numbers, the input tab on the driver station has live controller readings and axis/button numbers.
Unread 07-01-2015, 09:47
daniel12997's Avatar
daniel12997 daniel12997 is offline
Student
AKA: Daniel Parker
FRC #1736 (Robot Casserole)
Team Role: Student
daniel12997 is an unknown quantity at this point
Could you use one of the joysticks for forward backward and strafing and the other joystick for rotation.
Unread 07-01-2015, 11:07
LFRobotics's Avatar
FRC #4623
Im using command base but just any code examples will do - its easy to change over.
Yeah I was thinking about what daniel was saying - using one stick for x and y and the other for rotation - right now only one is being used.
Unread 07-01-2015, 11:22
LFRobotics's Avatar
FRC #4623
Okay here is what I was thinking - use L1 and R1 to turn slow and L2 and R2 to turn fast. Then use left joystick x to move left and right and left joystick y to move up and down - if I push up on the joystick AND move it right the robot should move diagonally - will this work and if so how would I implement it? I also want to be able to have a button - probably the up arrow and down arrow - that I can change the speed with.
THANKS for the help!
Unread 07-01-2015, 11:54
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
What size mechanum wheels and what gearbox ratio ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 07-01-2015, 12:18
Ethan_P Ethan_P is offline
FRC #1895 (Lambda Corps)
Ethan_P is an unknown quantity at this point
for mechanum wheels, our team also uses a Xbox controller. We have the right joystick axis mapped to the linear movement of the robot, and the the left joystick x axis mapped to the rotation.
Here's a simplified version of our code:
//FLMotor = Front Left Motor
//FRMotor = Front Right Motor
//BLMotor = Back Left Motor
//BRMotor = Back Right Motor
//x = right joystick, x axis
//y = right joystick, y axis
//yaw = left joystick, x axis
FLMotor = y + x + yaw
FRMotor = y - x - yaw
BLMotor = y - x + yaw
BRMotor = y + x - yaw
The values will have to be limited, other-wise it will go beyond the accepted values (-1 to 1). Make sure the wheels are set up properly, and good luck!
Unread 07-01-2015, 13:06
LFRobotics's Avatar
FRC #4623
6in and we have not decided on the ratios yet - what is suggested - also should we purchase Heavy Duty or Standard Duty wheels?
Okay thanks Ethan I think im starting to get a picture of what I need to do
Unread 07-01-2015, 14:20
Make sure you do the limiting via normalization, not clipping.
Unread 07-01-2015, 15:30
LFRobotics's Avatar
FRC #4623
And how exactly do I do that?
Unread 07-01-2015, 16:10
Search for the word "normalize" in these docs:
http://www.chiefdelphi.com/media/papers/download/2783
Unread 07-01-2015, 22:22
Mecanum Wheel's Avatar
Mecanum Wheel Mecanum Wheel is offline
It's spelled mecanum
AKA: Bengt Ilon
Mecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond repute
Hey LF, Andrew, and Ethan! Just for future reference, it's spelled mecanum. It's an easy mistake to make. Good luck this season!
Unread 07-01-2015, 23:17
Sl3dman's Avatar
Sl3dman Sl3dman is offline
FRC #1339 (Angelbots)
Rookie Year: 2015
Sl3dman is an unknown quantity at this point
I would start here. https://wpilib.screenstepslive.com/s...-mecanum-drive
Our team did our first mecanum over off season and found out that it was better to replace the "Get Z Axis" and "Get X Axis" and "Get Y Axis" with get raw axis with which ever ones you want. We put the X Axis to strafe left and right on axis 0 (left joystick X Axis). The Y Axis to go forwards and backwards on axis 1 (left joystick Y Axis). And for rotation, we put axis on the right X Axis on axis 4 (right joystick X Axis). Also make sure they your motor controllers are set up in the correct order when you set it up. Hopefully that helps some.
