Go to Post The game was once played on corn, for crying out loud. - Kimmeh [more]
Thread Tools Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Unread 07-01-2015, 11:22
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: Software Installation Notes from Toronto Quick Build
Originally Posted by Justin m View Post
I have been trying to install java on the roboRIO, but I am unable to locate the installer. I have tried finding it on 3 computers, all of which are fully updated with the 2015 suite. I cannot ind the wpilib folder in the home directory. Any help is greatly apprecated.
Are you sure that you've installed the eclipse plugins? Make sure that you open eclipse after installing the plugins, that's what creates the wpilib folder. See these instructions. http://wpilib.screenstepslive.com/s/...eclipse-c-java
This appears to be the log for my second attempt, where it also froze.
As for this error, I've never seen that error before. The fact that tar gave an error 2 likely means that the JRE tar was copied unsuccessfully to the roboRio and the .tar.gz was corrupted in some way. I'll see if I can reproduce the issue.
Unread 11-01-2015, 12:32
zeldathegood zeldathegood is offline
FRC #4277
zeldathegood is an unknown quantity at this point
Exclamation Re: Software Installation Notes from Toronto Quick Build
I"m having trouble installing java on the roborio. I freeze at downloading jre to roborio.
I am connected via USB
I have updated firmware using same connection
Windows 8
Here is the latest logs:
11/Jan/2015 11:30:06,841- CreateJreController: Staring JRE Creation
11/Jan/2015 11:30:06,841- CreateJreController: Creator location: C:\Users\Team 4277\wpilib\tools\ejdk1.8.0_06\lib\JRECreate.jar
11/Jan/2015 11:30:06,841- CreateJreController: Command: [java, -jar, C:\Users\Team 4277\wpilib\tools\ejdk1.8.0_06\lib\JRECreate.jar, --dest, JRE, --profile, compact2, --vm, client, --keep-debug-info, --debug]
11/Jan/2015 11:30:15,179- CreateJreController: Successfully Created JRE!
11/Jan/2015 11:30:24,987- ConnectRoboRioController: Connecting to roborio-4277.local
11/Jan/2015 11:30:24,990- ConnectRoboRioController: Checking for mDNS connection to the roboRio
11/Jan/2015 11:30:28,435- ConnectRoboRioController: Found mDNS connection
11/Jan/2015 11:30:28,436- ConnectRoboRioController: Connected to the roboRio at roborio-4277.local
11/Jan/2015 11:30:28,672- DeployController: Removed the old tgz file
11/Jan/2015 11:30:28,673- DeployController: Starting zip
11/Jan/2015 11:30:28,700- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE, putting tar entry is JRE
11/Jan/2015 11:30:28,702- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\bin, putting tar entry is JRE/bin
11/Jan/2015 11:30:28,703- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\bin\java, putting tar entry is JRE/bin/java
11/Jan/2015 11:30:28,706- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\bin\keytool, putting tar entry is JRE/bin/keytool
11/Jan/2015 11:30:28,708- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\bin\rmid, putting tar entry is JRE/bin/rmid
11/Jan/2015 11:30:28,715- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\bin\rmiregistry, putting tar entry is JRE/bin/rmiregistry
11/Jan/2015 11:30:28,717- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\bom, putting tar entry is JRE/bom
11/Jan/2015 11:30:28,720- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib, putting tar entry is JRE/lib
11/Jan/2015 11:30:28,722- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm, putting tar entry is JRE/lib/arm
11/Jan/2015 11:30:28,723- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\client, putting tar entry is JRE/lib/arm/client
11/Jan/2015 11:30:28,725- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\client\libjsig.so, putting tar entry is JRE/lib/arm/client/libjsig.so
11/Jan/2015 11:30:28,728- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\client\libjvm.so, putting tar entry is JRE/lib/arm/client/libjvm.so
11/Jan/2015 11:30:29,292- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\client\Xusage.txt, putting tar entry is JRE/lib/arm/client/Xusage.txt
11/Jan/2015 11:30:29,293- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\jli, putting tar entry is JRE/lib/arm/jli
11/Jan/2015 11:30:29,297- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\jli\libjli.so, putting tar entry is JRE/lib/arm/jli/libjli.so
11/Jan/2015 11:30:29,307- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\jvm.cfg, putting tar entry is JRE/lib/arm/jvm.cfg
11/Jan/2015 11:30:29,309- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libdt_socket.so, putting tar entry is JRE/lib/arm/libdt_socket.so
11/Jan/2015 11:30:29,313- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libhprof.so, putting tar entry is JRE/lib/arm/libhprof.so
11/Jan/2015 11:30:29,330- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libjava.so, putting tar entry is JRE/lib/arm/libjava.so
11/Jan/2015 11:30:29,348- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libjava_crw_demo.so, putting tar entry is JRE/lib/arm/libjava_crw_demo.so
11/Jan/2015 11:30:29,354- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libjdwp.so, putting tar entry is JRE/lib/arm/libjdwp.so
11/Jan/2015 11:30:29,392- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libjsig.so, putting tar entry is JRE/lib/arm/libjsig.so
11/Jan/2015 11:30:29,396- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libnet.so, putting tar entry is JRE/lib/arm/libnet.so
11/Jan/2015 11:30:29,406- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libnio.so, putting tar entry is JRE/lib/arm/libnio.so
11/Jan/2015 11:30:29,415- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libnpt.so, putting tar entry is JRE/lib/arm/libnpt.so
11/Jan/2015 11:30:29,418- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libverify.so, putting tar entry is JRE/lib/arm/libverify.so
11/Jan/2015 11:30:29,423- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\arm\libzip.so, putting tar entry is JRE/lib/arm/libzip.so
11/Jan/2015 11:30:29,435- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\calendars.properties, putting tar entry is JRE/lib/calendars.properties
11/Jan/2015 11:30:29,436- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\classlist, putting tar entry is JRE/lib/classlist
11/Jan/2015 11:30:29,447- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\content-types.properties, putting tar entry is JRE/lib/content-types.properties
11/Jan/2015 11:30:29,449- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\currency.data, putting tar entry is JRE/lib/currency.data
11/Jan/2015 11:30:29,451- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\ext, putting tar entry is JRE/lib/ext
11/Jan/2015 11:30:29,452- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\ext\meta-index, putting tar entry is JRE/lib/ext/meta-index
11/Jan/2015 11:30:29,454- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\ext\sunjce_provider.jar, putting tar entry is JRE/lib/ext/sunjce_provider.jar
11/Jan/2015 11:30:29,485- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\hijrah-config-umalqura.properties, putting tar entry is JRE/lib/hijrah-config-umalqura.properties
11/Jan/2015 11:30:29,487- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\jce.jar, putting tar entry is JRE/lib/jce.jar
11/Jan/2015 11:30:29,501- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\jsse.jar, putting tar entry is JRE/lib/jsse.jar
11/Jan/2015 11:30:29,535- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\jvm.hprof.txt, putting tar entry is JRE/lib/jvm.hprof.txt
11/Jan/2015 11:30:29,537- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\logging.properties, putting tar entry is JRE/lib/logging.properties
11/Jan/2015 11:30:29,538- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\meta-index, putting tar entry is JRE/lib/meta-index
11/Jan/2015 11:30:29,540- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\net.properties, putting tar entry is JRE/lib/net.properties
11/Jan/2015 11:30:29,542- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\resources.jar, putting tar entry is JRE/lib/resources.jar
11/Jan/2015 11:30:29,597- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\rt.jar, putting tar entry is JRE/lib/rt.jar
11/Jan/2015 11:30:31,158- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\security, putting tar entry is JRE/lib/security
11/Jan/2015 11:30:31,163- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\security\blacklist, putting tar entry is JRE/lib/security/blacklist
11/Jan/2015 11:30:31,165- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\security\cacerts, putting tar entry is JRE/lib/security/cacerts
11/Jan/2015 11:30:31,175- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\security\java.policy, putting tar entry is JRE/lib/security/java.policy
11/Jan/2015 11:30:31,179- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\security\java.security, putting tar entry is JRE/lib/security/java.security
11/Jan/2015 11:30:31,183- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\security\local_policy.ja r, putting tar entry is JRE/lib/security/local_policy.jar
11/Jan/2015 11:30:31,185- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\security\trusted.librari es, putting tar entry is JRE/lib/security/trusted.libraries
11/Jan/2015 11:30:31,186- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\security\US_export_polic y.jar, putting tar entry is JRE/lib/security/US_export_policy.jar
11/Jan/2015 11:30:31,188- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\lib\tzdb.dat, putting tar entry is JRE/lib/tzdb.dat
11/Jan/2015 11:30:31,202- DeployController: Processing file C:\Users\Team 4277\wpilib\tools\JRE\release, putting tar entry is JRE/release
11/Jan/2015 11:30:32,283- DeployController: Failure to send JRE to the roboRio
com.jcraft.jsch.JSchException: java.net.ConnectException: Connection refused: connect
at com.jcraft.jsch.Util.createSocket(Util.java:349) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:215) ~[java-installer.jar:?]
at com.jcraft.jsch.Session.connect(Session.java:183) ~[java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController.lambda$initialize$10(DeployControlle r.java:85) [java-installer.jar:?]
at edu.wpi.first.wpilib.javainstaller.Controllers.Dep loyController$$Lambda$160/1605457580.run(Unknown Source) [java-installer.jar:?]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_25]
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method) ~[?:1.8.0_25]
at java.net.DualStackPlainSocketImpl.socketConnect(Un known Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connectToAddress( Unknown Source) ~[?:1.8.0_25]
at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.PlainSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.connect(Unknown Source) ~[?:1.8.0_25]
at java.net.Socket.<init>(Unknown Source) ~[?:1.8.0_25]
at com.jcraft.jsch.Util.createSocket(Util.java:343) ~[java-installer.jar:?]
... 5 more
Any help would be greatly appreciated.
Unread 11-01-2015, 13:23
FRC #4277
I couldn't find the installer at first. It turns out that the National Instruments stuff in in both the Programs Files and the Program Files (x86). The java installer is in the Program Files (x86)
Unread 11-01-2015, 14:19
WPILib Developer
FRC #0190
You said you updated the firmware, but does that include imaging roboRIO with the imaging tool? The connection refused error you're getting should only occur when the roboRIO doesn't have the v23 image on it.
Unread 11-01-2015, 14:34
FRC #4277
I did both the firmware and then image v23.zip
I have tried both usb and ethernet connection also
Unread 11-01-2015, 14:56
WPILib Developer
FRC #0190
Do you have ssh installed on your computer? What happens if you try to ssh to admin@roborio-4277.local, no password? The line the installer is failing on is when it attempts to log into the roboRIO with the username admin and the blank password, and it's failing to do so. I would first try rebooting your roboRIO, and if that fails, then reimage it.
Unread 11-01-2015, 15:41
FRC #4277
I have reimaged it a couple times
Restarted the laptop
Restarted the roborio
Hit reset
Can you give more info on the ssh?
Unread 11-01-2015, 16:22
FRC #4277
Red face Re: Software Installation Notes from Toronto Quick Build
3rd time is a charm
I re-imaged again and seem to be moving on
Thanks for your help
Unread 15-01-2015, 10:40
FRC #4277
Talking Re: Software Installation Notes from Toronto Quick Build
Thanks so much for posting the quick start list. It was very helpful. We did find that we also had to set JAVA_HOME and update the PATH on our drivers station so we could deploy.
