Go to Post Robotics is about people. It always was, it always will be. What more guidelines do we need? - Ken Leung [more]
Unread 06-01-2015, 13:21
msto msto is offline
Rookie Year: 1000
msto is an unknown quantity at this point
Searching for a minimal USB camera
The tested cameras this year (Axis, Microsoft LifeCam 3000) are much more expensive and have more features (auto focus, color adjustment) than I'd like. I'm currently planning to use one or two cameras for internal monitoring on the robot (to fully understand when things go wrong on field), and those cameras are overkill. (I'm also working on a robotic EDD project that has a very low budget).
Has anyone found, used, or seen a good camera that comes closest to these minimum requirements?
* 320x240 pixels at 10 fps.
* USB interface to an ARM Linux computer (roboRIO or ODROID). Preferably over GenICam interface, since that's already on the roboRIO.
* Does not need to be in color.
* No mounting requirements (a raw PCB is fine).
* Does not need to auto-focus.
Unread 06-01-2015, 13:32
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: Searching for a minimal USB camera
I do know webcams pulled from dead laptops are pretty compact and dirt cheap on ebay; I have a box of them myself (that I never got to using). Sure, they're color 1.3MP (some with microphones), but unless it is from a sony vaio (or anything else using Ricoh webcam chips), it should linux up. To interface, either splice/add a usb plug/cable to the old connector (which many times will use somewhat standard wire colors). If over 16' cable length, use a repeater cable just to be safe.
Unread 06-01-2015, 13:39
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
You can usually get the PS3 eye camera quite cheaply on ebay, and it supports low res (though high framerate). I've gotten this camera to run on both the BeagleBone Black and the Jetson TK1. It has some brightness correction and auto-focus though, if that is a deal breaker.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 06-01-2015, 15:05
Rookie Year: 1000
Extra features aren't bad for my needs, simply more than I need. Features aren't deal breakers: I mainly want to reduce price.
Thanks for the advice.
Unread 06-01-2015, 17:03
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
$25 is too expensive for a camera?
Unread 06-01-2015, 17:20
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
The ones on FIRST Choice are pretty small, and free
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 07-01-2015, 05:43
ratdude747's Avatar
AKA: Larry Bolan
Dead laptop webcams are usually $5 or less on fleabay... or if you know anybody with a few dead laptops/guts in a file cabinet (like me ), barter/free. Yesterday I pulled apart a beat to **** (but still running, sorta) 13" toshiba from 2007 and sure enough, a narrow little webcam module came out of the lid that from pre-parting testing, is a pretty basic 1.3MP UVC webcam. Another one in the pile...
Unread 07-01-2015, 15:10
buchanan buchanan is offline
FRC #2077 (Laser Robotics)
buchanan is just really nicebuchanan is just really nicebuchanan is just really nicebuchanan is just really nice
PS3 Eye cameras are $8 from Amazon in bulk packaging. High frame rate, low latency, low motion blur, acceptable image quality. These are my favorite of the several I've tried.
Unread 26-01-2015, 15:11
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
I got a couple of these and I can't get my Laptop to even recognise them as cameras, only audio inputs. No S/W included... is there a trick to get them to work?
Was your reference based on FIRST usage, or something else....
Phil Malone
http://www.GEARSinc.org
Unread 26-01-2015, 15:17
wt200999's Avatar
Texas Instruments
AKA: Will Toth
I also referenced it, but based on outside usage. I've used the ps3 eye before on the beaglebone and Jetson TK1, though only the beaglebone has the proper kernel module built on it, which is the gspca-ov534. The Jetson board and the roboRIO do not have it. So to get it to work with the roboRIO you would have to compile and load it yourself.
I know NI has their kernel on github but I haven't seen anyone try to build it or any kernel modules for the roboRIO.
