Go to Post You will "generously donate" your game pieces into your opponent's goal. - johnr [more]
Unread 07-01-2015, 16:02
iLikePie's Avatar
iLikePie iLikePie is offline
Pie Be Good
AKA: Wolfgang
FRC #3574 (High Tekerz)
iLikePie is on a distinguished road
Talking Unlimited Cooperatition Points
I just made a Chief Delphi account because I think I found a way to get a TON of points.
(Everything below here can be found under 3.1.2.2 of the FRC game manual.)
Cooperatition stack requirement C:
the entire structure is free from contact from ROBOTS for a least three (3) seconds
Last paragraph of 3.1.2.2:
points for a ... COOPERTITION STACK are awarded instantly upon successful completion.
It looks like to me you can make a Cooperatition Stack, let it stand for three seconds, and then take it down and rebuild it for 40 more points!
Please let me know what you think.
Unread 07-01-2015, 16:53
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Unlimited Cooperatition Points
Sounds sort of valid, maybe it was intended, but I think 'unlimited' is not the case, since those 3 seconds add up and eventually you run out of time.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Link07 Link07 is offline
Volunteer
AKA: Andrew
Link07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant future
It seems you are misinterpreting the way in which Coopertition is scored: once per match, very much like the bridge in 2012. The wording of the manual in its discussion of Coopertation supports this.
Coopertition Points are awarded if, at some point in the Match, there are at least four Yellow Totes on the Step simultaneously. Coopertition Points are doubled if the Alliances arrange at least four of those Yellow Totes in a single stack on the Step.
Emphasis mine.
The 20 or 40 points are awarded on a once per match basis if the conditions were met at some point and for at least 3 seconds in that match, and not per instance of stack formed.
Additionally, the field status light will turn white once a stack has been reached. The match display will also display a symbol indicating the set or stack has been reached.
Unread 07-01-2015, 17:00
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Yeah, while the rules never explicitly say "Coopertition points will be scored at a maximum of 40 points", its clear to see that this is what they meant. Its good that you guys are thinking about these sorts of things though.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 07-01-2015, 17:07
iLikePie's Avatar
Pie Be Good
AKA: Wolfgang
OK technically it not unlimited.
Link07, Where does it say that in the rules?
dellagd, also, were did you see that in the rules?
Unread 07-01-2015, 17:16
RallyJeff's Avatar
RallyJeff RallyJeff is offline
FRC Referee & FLL Many-Hats-Wearer
AKA: Jeff Hagan
Rookie Year: 1995
RallyJeff has a spectacular aura aboutRallyJeff has a spectacular aura aboutRallyJeff has a spectacular aura about
The blue box text after Figure 3-2 says that an alliance can get points for either a coopertition set or a coopertition stack in match.
Unread 07-01-2015, 17:19
Volunteer
AKA: Andrew
Adding on to what others have said, it is clear that this was the intent of the game.
If points are awarded for a COOPERTITION SET and a COOPERTITION STACK is formed at a later time in the MATCH, the COOPERTITION SET will be upgraded and instead awarded points for a COOPERTITION STACK.
ALLIANCES can earn points for either a COOPERTITION STACK or a COOPERTITION SET in a MATCH, but not both.
So are you suggesting that you can get an unlimited amount of EITHER STACKS or SETS, but not a mix of the two? If I have 5 different instances of SETS, are they ALL upgraded if I later make a STACK? I hardly think that this is the GDC's intent at all.
dellagd's Avatar
AKA: Griffin D
Like I said, you are correct in that the manual does not explicitly state that a COOPERTITION STACK can be awarded points multiple times. That doesn't mean its going to be scored that way. I mean, just look at the new scoreboard design. Obviously they only intend to award a max of 40 points for any coopertition. Honestly after Frank sees this thread I'm sure we'll see a Team Update on it.
So what, I could do unlimited stacks, but the instant I have a set there one of the two is nullified? Once again, I know this doesn't totally refute what you're saying, but the intention of that sentence is clear. As for the emphasis of the 'a' in the sentence, technically we're only taking about one stack scored multiple times, so it would still technically work with that lawyer logic.
Yeah, not gonna happen :/
Unread 07-01-2015, 17:25
iLikePie's Avatar
Pie Be Good
AKA: Wolfgang
Pretty much.
Unread 07-01-2015, 17:51
Volunteer
AKA: Andrew
Pretty much.
I would suggest submitting your question to the Q&A then, if you don't think that the information in this thread proves (or, at least, heavily implies) your proposal to be non-viable.
If your game strategy is to just continuously get Coopertition points in the match, I guarantee you will be quickly disappointed at your first event.
Unread 07-01-2015, 17:57
iLikePie's Avatar
Pie Be Good
AKA: Wolfgang
Oh no, that's not my teams strategy; I just thought it was interesting that there was nothing that said you couldn't do it.
Unread 10-01-2015, 10:23
Horsepower3172 Horsepower3172 is offline
FRC #3172
Horsepower3172 is an unknown quantity at this point
This will probably not be legitimate, because if this is possible, the COOPERTITION spamming, then nothing else in the game will matter. Everyone will be focused on stacking, there will be no variety, and these factors would probably make this season the least diverse of them all.
