Go to Post Remember guys, if your mentor wasn't there, odds are, you wouldn't be either. - Corey Balint [more]
Unread 07-01-2015, 13:37
pipsqueaker pipsqueaker is offline
FRC #1124
pipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to all
How many encoders are needed to control an H/slide drive?
We're planning on going an H drive this year, and our coder says that he wants five encoders, one on each wheel.
My interpretation of H-drive is basically that it is a tank drive with an extra wheel in the middle. This should mean that both wheels on the left and right are being driven in the same direction at the same rate- because of this I think that one encoder per side is fine, as the wheels will be driven with the same motors and gearboxes in an identical manner- our coder says that, because the two wheels on a side wont be driven by the same motor/gearbox, we will need to place an encoder on each wheel to correct for any tiny variations.
To me this seems excessive and inconvenient (5 encoders will take up all our DIO ports on the roborio, requiring me to expand it). I just wanted your opinions on whether we truly need an encoder on every single wheel.
EDIT: I should clarify, the encoders are for autonomous stuff, we're not really planning on using them in teleop
Unread 07-01-2015, 13:43
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: How many encoders are needed to control an H/slide drive?
When we did ours in 2011, we used three encoders. It worked well.
Unread 07-01-2015, 13:45
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
5 encoders certainly aren't NEEDED. 4 on the main drive will allow programmers to be able to speed match the 4 wheel, which will allow the best possible "drive straight" functionality in autonomous. You can get away with 2, but you won't be able to guarantee all 4 main drive motors are turning at the same rate then.
The 5th motor encoder would only be needed if you planned to do any strafing in autonomous.
Unread 07-01-2015, 13:46
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
2011 was flat, how do you feel about using three when trans-versing the bump, slippage on some wheels and not others affect anything?
DISCLAIMER: I am not a programmer, just interested.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 07-01-2015, 13:49
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
You would want 5 encoders, if you were powering each wheel separately. But if you aren't going to power each wheel separately, that is a non-issue. I'd imagine you would want 3 total, for drive. One for the left side, with the encoder attached to the gearbox output shaft (Well, the little doohickey that sticks out for encoders), same thing for the right side, then one encoder on your center motor (for the H drive). (Not necessarily on the motor itself, of course. But I'm sure you know where to put it.)
Even if you wanted to use more than 5 or 6 encoders, without expanding the DIO ports on the roboRIO, the Jaguars DO have a built-in interface for encoders, that are accessible via CAN. (The Talons might have them also, you'll have to look that up).
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 07-01-2015, 17:04
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Talons. Talons, Talons, Talons. The encoder input on the Jags is nearly useless. It won't give you feedback unless you're actually using a closed-loop control mode. And its closed loop controls aren't all that great. And you can only use one encoder and one Jag to drive one motor, unless you're doing something to split the encoder signal, because there's no way to slave on Jag to another. Talons on the other hand give you a constant feedback stream of both velocity and position, so you could put the PID on your roboRIO, or use the PID on the Talon. And if you're in velocity mode, you can still get position feedback for all your autonomous needs.
Unread 07-01-2015, 17:06
AKA: Matt B
FRC #1771 (1771)
Okay cool! Like I said, I wasn't sure about the capabilities of Talons.
As for the closed loop part of the Jaguars, I suppose that's true. I've only ever used them with closed loop, I never anything else.
1771- Mentor (2015)
Unread 07-01-2015, 17:08
Actually I should amend that to Talon SRX. The original Talon and Talon SR controllers aren't CAN capable, after all.
Unread 07-01-2015, 17:09
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
wont that center wheel on the H drive cause a problem going over the bump?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 07-01-2015, 17:32
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
Only if it is in a fixed in position. Or... Are there other ways to obtain H drive motion with a different position/number of omni wheels?
Unread 07-01-2015, 17:49
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
1736 used Jags via CAN in 2012 and we were able to read speed while in open loop to implement PID on the cRIO. From BDC comm, I remember having to switch to closed loop, configure the encoder, and switch back to open loop to see speed. This wasn't an issue on the robot though.
Unread 07-01-2015, 19:02
Yes.
http://www.chiefdelphi.com/forums/sh...4&postcount=11
Also try searching for the words "Killough" and "Kiwi" here on CD
Unread 07-01-2015, 21:36
We put the encoders on non-driven follower wheels that year. They were Vex omni-wheels mounted to tiny swing arms spring loaded to contact the ground. Therefore, no real worries about wheel slip.
Unread 08-01-2015, 08:24
Dancing Drive Coach
Yes.
Thanks Ether, though it was more of a question for BruceB and Pipsqueeker. Our team thinks we have figured out a way to use all omni and get over the scoring platform.
