Go to Post I guess instead of focusing on the stuff we wish we could have changed, we should focus on all of the wonderful stuff we accomplished instead! - Winged Wonder [more]
Unread 07-01-2015, 17:55
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
is it actually possible to get six levels of totes?
Yes, you can make a robot to do that, but i have seen people say that if you build the totes too tall it wont score when you put a container on it, and i am unable to find a rule that exactly explains if there is a limit how tall you could make the stack before it would be too tall to score. Am i just blind, or is there a limit to how tall i could make the stack before putting a container on it useless pointswise?
Unread 07-01-2015, 18:09
wajirock's Avatar
wajirock wajirock is offline
Safety General
AKA: Mohammed W.
wajirock has a spectacular aura aboutwajirock has a spectacular aura about
Re: is it actually possible to get six levels of totes?
Yes it is possible to get make one. Totes past the sixth level will not be scored, but as long as the lowest point of the RC is bellow the sixth level, you will get the points for it.
Unread 07-01-2015, 18:10
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
The rule specifying how totes are scored has an illustration suggesting that "level 6" extends to an infinite height upwards. This means that, even though the recycling container can rest on more than 6 stacked totes, all of the totes at the beginning of level six and up will be considered residing in level six, and hence, even if there are more than six totes under it, as the container's bottom resides in level six, it will score 4pts*6levels= 24 points. There appears to be no factor that would limit the height it would be scored at.
Unread 07-01-2015, 18:13
StillDefective's Avatar
StillDefective StillDefective is offline
In the shop, got my stock, CNC on.
AKA: Paul Johnson
FRC #1094 (Channel Cats)
StillDefective has a spectacular aura aboutStillDefective has a spectacular aura about
I forgot the exact rule, and I coudn't find it, but any totes that extend above the backstop will not be scored, so a stack of 6 would only score 5 totes, so the point is rendered moot.
Unread 07-01-2015, 18:25
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
That is incorrect. A stack of 6 would score 6 totes. The marker on the side of the scoring zones is made so that only 6 totes can be scored. Frank said in his blog that any totes above 6 wouldnt be counted.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 07-01-2015, 19:05
GaryVoshol's Avatar
Cogito ergo arbitro
3.1.2.3 says
A RECYCLING CONTAINER is scored if it is fully supported by only scored Gray TOTES.
Since the 7th gray TOTE in the stack is not scored (because it's above the BACKSTOP), the CONTAINER is not supported by only scored TOTES. It's also supported by an unscored one. I could see why that CONTAINER wouldn't count.
Somebody please ask Q&A. (I don't have a team, so I can't.)
(since 2004)
Unread 07-01-2015, 23:17
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
3.1.2.3 says
I would venture to guess this rule will be re-worded. It is my understanding that a stack of 7 totes with a can and a noodle will score 42 points, the same as a similar stack of 6 tall.
Unread 07-01-2015, 23:20
dodar's Avatar
Originally Posted by Skyehawk View Post
3.1.2.3 says
But it isnt supported by scored totes. That 7th tote isnt scored.
Unread 08-01-2015, 08:10
sviridovt sviridovt is offline
FRC #5329 (S(A^3)S Robotics)
sviridovt is on a distinguished road
According to the team update, they purposely limited the number of totes in a stack to 6 for safety and field reset reasons (any higher would take too much time to reset, and have a high chance of falling over), however they didnt want to penalize teams who didn't read/understand the rule which is why any totes beyond 6 are just not scored.
Unread 08-01-2015, 09:02
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Under 3.1.2.3, in the TOTES section:
A Gray TOTE is scored if it is fully supported by a SCORING PLATFORM and no portion of the TOTE extends above the top of the
BACKSTOP
It seems pretty clear that a Gray TOTE that is higher than a BACKSTOP is not scored.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
