Go to Post it doesn't matter so much why i joined [FIRST], but that i stayed :D - sure_smile [more]
Unread 06-01-2015, 22:12
Asymons Asymons is offline
FRC #4716 (Purple Raiders)
Team Role: Driver
Asymons is an unknown quantity at this point
Opinions on the AndyMark Dual Use Gyro and Accelerometer Sensor Board (am-2067)
Hello Everyone!
I hope everyone is having a good start to their build season! I have a question regarding the Andy Mark Dual Use Gyro and Accelerometer Sensor Board (am-2067). Has any team had success with this Gyro for simply measuring the angle of the robot and moving straight? Would there be a better Gyro for what I am looking for? Thanks for your time.
Unread 07-01-2015, 06:16
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Re: Opinions on the AndyMark Dual Use Gyro and Accelerometer Sensor Board (am-2067)
We've used that gyro for several years and it's been good enough. I think we've put it on 2 6WD designs and two Mecanum designs. It's purpose was the same as what you intend - to assist in going straight over uneven surfaces or when getting pushed around. The analog interface makes it pretty easy to use.
The Analog Devices ADW22307 is an old gyro and I don't believe you'll find one much longer. It doesn't seem to exist on the Analog Devices web site. Most of the new stuff is smaller, MUCH cheaper, and uses a digital interface.
Unread 07-01-2015, 07:07
ShinyShips's Avatar
ShinyShips ShinyShips is offline
Former Operator and Captain
AKA: Andy
FRC #3314 (Mechanical Mustangs)
ShinyShips is on a distinguished road
We used this gyro on our mecanum last year, it worked fine for our field-oriented drive and keeping straight. It measured angle pretty well, but it drifts a bit so you'll have to compensate. We got it down to only a few degrees drift with some temperature compensation.
There probably are better gyros on the market, but for now that is what we are using.
Unread 07-01-2015, 19:00
Team Role: Driver
Thanks for the input. Our team was personally wondering whether we purchase it on the AndyMark site (that model) or purchase the ADXRS450Z a newer model. I think we will be going for the newer model just so that we don't run into as many problems in the future.
Unread 07-01-2015, 19:17
The ADXRS450 is a digital gyro, so it won't work with the gyro class in WPILib. You'll need to write your own driver and integration.
