Go to Post The more time we spend there, and the more investment we have in the team, the more rewarding it is. - ILAMtitan [more]
Unread 07-01-2015, 19:20
sasha831 sasha831 is offline
Sasha
FRC #4529 (AI Robotics)
sasha831 is an unknown quantity at this point
Lightbulb Mount Middle Slide Wheel
For teams considering a slide/H-drive, how were you planning on mounting the centre wheel?
Theory is when you know everything but nothing works. Practice is everything works but no one knows why. On our Team, theory and practice are combined: nothing works and no one knows why!
Unread 07-01-2015, 19:38
TankerRed101's Avatar
TankerRed101 TankerRed101 is offline
AKA: Michael Bank
FRC #3284 (LASER)
Team Role: Student
TankerRed101 is an unknown quantity at this point
Re: Mount Middle Slide Wheel
We were going to put a spring or something else as a shock so when it hits the ramp the wheel doesn't bust.
Unread 09-01-2015, 00:43
Skyehawk's Avatar
Skyehawk Skyehawk is online now
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
This is indeed a very good point, what about teams considering kiwi drive? There will be some similarities w/ the problems of slide like you mentioned.
Unread 09-01-2015, 00:48
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
I don't know how well you'll be able to go over the ramp with kiwi in the first place.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 09-01-2015, 02:54
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Easy. Just drive up (a little momentum might help). I do know 1501 ran a small wheeled kiwi drive in 2010 and was able to get up the ramp to the goal... sure they couldn't do the bumps, but that was 45 degrees and much higher than the 16 degree 2" scoring platforms we're talking.
I think people seem to underestimate the ability of rollered wheels (omni and mecanum) to go up ramps and the like... if anything in the "slow" modes act like a gear reduction, similar to how pulleys work (trading speed for transitional force). Sure, wheel contact is an issue... but on a kiwi, unless you bottom out and drag the frame (could happen with lower ride heights), being a 3 point system, all 3 wheels will always be in contact with something.
This is an old argument... people said the same about mecanums in 2010 and 2012 (Bumps and bridges respectively)... and I saw examples of such drives work pretty much flawlessly both years. If you design the drive right, mecanums are plenty capable of ramp handling.
Unread 09-01-2015, 07:39
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We're modifying a KOP drive chassis to H-drive, using a spacer instead of the center wheel. We were thinking about just using a couple of angle aluminum brackets to hard-mount another copy of the same gearbox 1/8" higher than the built-in gearboxes. We aren't planning to drive up the ramp, but makes me realize we either need to provide suspension to let it happen, or provide some safeties so that we don't slam the wheel into the platform.
Unread 09-01-2015, 07:50
dradoxen dradoxen is offline
CAD/Mechanical Mentor
AKA: Dominic Doxen
FRC #0910 (Foley Freeze)
dradoxen is an unknown quantity at this point
Correct me if I'm wrong, but if you were to move your center wheels to be in between your other two sets at 90 degrees, you would not need a suspension.
This design does require extra weight, with an extra gearbox, wheel, and support, because you need a center wheel on both ends of the robot but as a team with less build capabilities we found it to be easier to implement than a suspension.
Am I missing anything with this?
Unread 09-01-2015, 09:15
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
This was our thinking. Though we are concerned with all 3 wheels being in contact with the ground at all times. So perhaps still having a passive system that provides some force downward on the slide wheels, but has enough travel to be compressed if need be over the platform? We still need to figure out how to mount these the kit chassis. If anyone has any ideas it would be appreciated.
Unread 09-01-2015, 09:30
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
We are going to try putting our strafe omni in line with our front drive omnis. This should work well when holding totes as most weight is on the front. Without totes, we will use a gyro and compensate for turn by diff steering the outer wheels a little. Might not be perfect, will see how it works.
For mounting, I'm thinking we purchase another inner rail to bolt in place and mount gearbox to with live hex and a bearing in the front rail. Probably need to drill out a wheel bolt hole to a hex bearing as we won't want any drop.
Unread 09-01-2015, 09:32
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
3061 is using a 'fork' style suspension where the gearbox drives one of two wheels into the ground. We like it because unlike spring systems it does not take weight off of our drive wheels when the strafing wheel is unpowered.
Unread 09-01-2015, 09:40
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
It is not necessary to have the strafe wheel on a suspension. That being said, make sure you have a very good way to drive around the field and not hang up. We have gotten away without one so it eliminates complexity.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 10-01-2015, 08:48
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Unless you're about to tip over, this will always introduce a torque so that the front will turn in the direction of the strafe. You can correct, but it's better to have a system that almost works without the feedback loop than one which is uncontrollable without it. The COG is the best place - the question is, with how much load to you optimize? We're looking to mount our strafe wheel onto a piece of aluminum angle or two which bolt to the holes on the top and bottom of the side rails (we're using the KOP chassis). Then, we can adjust this placement relatively easily when we find the COG. This could still be used with sprung suspensions.
Unread 10-01-2015, 09:08
jeremylee's Avatar
Agree it's not ideal, but we want to cross the scoring platform without getting hung up and wothout the complexity of a raiseable wheel. If it becomes a problem even with a gyro, we may add another omni on the other side.
Unread 10-01-2015, 09:34
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Just as another data point, here is a kiwi drive attempting to drive up a non-carpeted incline: http://www.thebluealliance.com/match/2007il_qm37
Unread 11-01-2015, 10:23
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
If you do, put it on a separate gearbox, or have a differential between them so that you don't create a counter-torque when rotating or turning.
