Go to Post The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance. But after a little thought, something tells me that I probably should not do it. - dlavery [more]
Unread 03-01-2015, 14:15
SJohnTrombley's Avatar
SJohnTrombley SJohnTrombley is offline
FRC #0020 (The Rocketeers)
SJohnTrombley is on a distinguished road
roboRIO Imaging Problems
I'm following the imaging instructions at https://wpilib.screenstepslive.com/s...o#!prettyPhoto and, after opening the roboRio Imaging Tool, it has gotten to "Getting startup settings from roboRIO target..." and has been waiting there for quite some time. Anyone else have this problem? Pic related.
Unread 03-01-2015, 14:35
Re: roboRIO Imaging Problems
I rebooted my PC, it worked.
Unread 03-01-2015, 15:16
mlanglois's Avatar
mlanglois mlanglois is offline
AKA: Matt
FRC #1305 (Matt Langlois)
mlanglois is an unknown quantity at this point
Where can you download the Roborio imaging tool?
Unread 03-01-2015, 15:38
nwall nwall is offline
It's a hardware problem
AKA: Nicholas
FRC #0418 (LASA Robotics)
nwall is an unknown quantity at this point
The RoboRIO Imaging tool is installed as part of the FRC 2015 update, and is found at
64-bit:
C:\Program Files (x86)\National Instruments\LabVIEW 2014\project\roboRIO Tool\roboRIO_ImagingTool.exe
32-bit:
C:\Program Files\National Instruments\LabVIEW 2014\project\roboRIO Tool\roboRIO_ImagingTool.exe
Unread 05-01-2015, 19:12
JamesD's Avatar
JamesD JamesD is offline
[:o)
AKA: James David
FRC #0330 (BeachBots)
JamesD is an unknown quantity at this point
You may need to turn off the Windows firewall or other security software on your PC.
Unread 07-01-2015, 18:57
Manusha4Lyfe Manusha4Lyfe is offline
FRC #5124
Manusha4Lyfe is an unknown quantity at this point
When I try to image the roboRio, i get this error. Any suggestions? Pic related.
Unread 07-01-2015, 19:41
FRC #5124
Nevermind, it worked
Unread 11-01-2016, 18:21
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
MasterEric is an unknown quantity at this point
I had this problem too, and restarting worked.
Thanks for posting your solution instead of just saying "never mind fixed it"
